Diagnostic ports?
Re: those are them...
so which port is A and which is B ? Sorry Dave but I'm sh##ing myself in case I F### this up.<ul><li><a href="http://www.20v.org/fault.htm">http://www.20v.org/fault.htm</a</li></ul>
Uh...without bentley I couldn't tell you...
They each have a unique shape, and are obviously colour coded...and my bentley knows which is which...but I don't.
So, uh, either wait until I get home...or hopefully someone else posts!
-Dave
-Dave
Re: Uh...without bentley I couldn't tell you...
Once again Dave youre doing me a huge favor! Cheers! Just e-mail me if you come up with anything. Wont do it until weekend probably.
A B3 is beneath the driver's side lower dash panel - near pedals.....:
A = black
B = brown
According to the pic, "A" has the tapered angle on the 'narrow' end. "B" has the tapered angle on the wide side.
`_
| | =A
|_|
__
| | = B
|_/
Well, you get the idea
B = brown
`_
| | =A
|_|
__
| | = B
|_/
A is dark, B is light.
if I had my scanner I'd scan the photo...but I don't, so I'll try to explain.
A is the dark connector. When you are looking at the contacts in the connector, it should be orientated so that the flat part of the housing is the 'bottom'. The lower contact is the negative termanil, the top is the positive.
The B connector is the light one. When looking at the contacts the body will appear to be shaped like a 'D', with the long flat part on the left. Looking at bentley, this is kind of irrelavent...as B should only have one connection in it.
No sense in emailing you...then the answer isn't in the audiworld archives, and I look like a jerk when I tell some noob to search the freaking forum!
-Dave
-Dave
FatAuto
12-19-2003 07:43 AM
PGTT
31
02-26-2002 07:15 AM
