duelling temp. sensors
1989 90 10v.
The inexpensive and plentiful temp. sensor that goes where the upper radiator hose goes into the block is this:
https://www.fcpeuro.com/products/aud...sor-0280130053
But.
What is this, is it different, and where does it go? Is it even on my engine? It is greatly more expensive, quite rare, and is visually different.
https://www.ecstuning.com/b-genuine-...ble/034906163/
And if my car indeed even has both, could someone describe what each does, technically? Including where the data is actually going from each sensor?
Thank you!
But.
Thank you!
Several different types of those thermal sensors are made. With A/C, with or without a catalytic converter, diesel engine..so forth.
Here in the USA the part number you need is (I think) 034906161. If yours is black/dark brown.
You may need to remove the old one. Audi was good at putting part numbers on those. See if the link helps..look at #10
If the part in 034906161 it is available and very inexpensive. About $5
Audi Oil pressure switch temperature switch thermal switch temperature sender switch thermal switch for back-up light back up lamp switch switch - altitude corrector switch for air conditioner switch - altitude corrector
S4gasm (LoTR)
01-09-2006 01:27 PM
RootMachine
05-25-2005 06:45 AM
boom132
06-05-2004 11:18 AM
