H4 silver stars from powerbulbs.com...are they 55/60w?
<center><img src="http://www.powerbulbs.com/products/osram/silverstarh4.jpg"></center><p>I couldnt verify on the site, anyone know for sure? The importvision euros should be in monday, and I know I need to pick up the harness plugs, bulbs, and grommets. TIA.
if it's 85 or 100 watts, they would advertise it
most if not all bulbs is 55 or 65 watts, it just depends how they measure lumens
usually higher watts means they measured it at peak just like max or rms power of a stereo amp.
Re: H4 silver stars from powerbulbs.com...are they 55/60w?
Got my set here in my hot little hands and they are 55/60. Be very, VERY careful with the plugs on the bacside of the housings on the DEPO lights, I punched one out just trying the plug on. Plug part numbers is 4A0-971-966 @$10.76 each and the grommets are 4A0-941-189 @$4.26 each both from the dealer. I'm still working on the harness but plan on relays with a 20 amp minimum contacts. Good Luck!
OldSkewS4
03-07-2003 02:11 PM
