How to change turbo's on an S4! :o(
AudiWorld Expert
<center><img src="http://www.s4girl.com/maintenance/turbos/images/IMG_2611.JPG"></center><p>This is refered to as the "easy way"<ul><li><a href="http://www.s4girl.com/maintenance/turbos/index.htm">http://www.s4girl.com/maintenance/turbos/index.htm</a</li></ul>
Actually that's the easy way....
I've seen people do a KO4 swap on their back, jackstands, with a cherry picker - which would be the way I'd have to do it now that I have no lift and no engine dolly to set it down on. That way takes up so much less time - crossmember and suspension down with engine, disconnect tranny, and raise the vehicle up on the lift, leaving the engine behind. LT1's come out real easy that way. 3.8 Windstars ring a bell too. But 22K - that's pathetic, and exactly why Audi ran with their tail between their legs and decided on the NA V8 on the B6. They've lost soooooooooo much money on warranties from K03's - all they had to do was use K04's, like the RS4, and none of this would have happened - or - kept the AAN. I would have opted for plan B.
