MIL-H-5606 Aircraft Hydraulic Fluid as substitute for Pentosin?
Just wondering if anyone knows was type of seals are used in our Audis' power steering system. MIL-H-5606 fluid used in aircraft hydraulic systems is mineral based fluid that seems very similar to Pentosin, and is only $20 or so a gallon. 1/4 the price of Pentosin from the dealer. This fluid is compatible with the o-ring materials listed here: http://www.efunda.com/designstandards/oring/oring_chemical.cfm?SM=none&SC=MIL-H-5606
Can anybody confirm that this will work in our cars?<ul><li><a href="http://www.wicksaircraft.com/catalog/product_cat.php/subid=1561/">http://www.wicksaircraft.com/catalog/product_cat.php/subid=1561/</a</li></ul>
No! We aviation types don't even use it on Aircraft!
Its used to "preserve" hydraulic components, until they can be placed in service. Normally we use Mil-H-83282, Type II. However its specificly designed for certain operating enviroments, and seals. Place it in your car, and it will eventually eat thru the seals...
Almost all general aviation planes use 5606 in the oleo struts, hyd actuators, and brake systems...
Most military and all transport category planes use Skydrol which isn't flammable. 5606 is used in GA planes because it is cheaper, although flammable. I've serviced many oleos and brake systems on small Cessnas with 5606 per the manufacturer's instructions.
I just don't see the benefit outwaying the possible problems that could and probably will occur...
I meen you just purchased a new rack. Why would you want to take the risk of ruining it? The pentosin to fill the system would probably be $5x, if you use the aviation stuff you would probably save $40 at the most? Now is that money worth it if you have to buy a new rack and other associated parts that will add up big time in the long run? In my and I think Miktip's opinion I think not... Just go with what you know works.
Jon-1.8t
01-18-2006 09:57 AM
Hokie - STI avant
09-27-2004 06:09 AM
5000tq, 5606, 5606g, adjusting, audi, brake, fluid, hydraulic, mil, milh5606, milh5606ga, pentosin, red, substitute, substitution
