my emergency brake light comes on after turns....luxus didnt u have htis problem?
when i turn the vehicle the brake light comes on, and when the vehicle is stable and going straight, the brake light comes off. Is ther ea sensor which is going bad and is now touching?
also hwere is the coolant temp sensor on a b4 90.
thanks
thanks
Hows the brake fluid level in res?
<center><img src="http://www.elcats.ru/imaudivw/VAG02C90.gif"></center><p>If its fine, then its sensor(#8) is probably bad.
Its a magnetic sensor, and can be changed. I had to change mine a couple years ago.
ahhh ok. So the engines coming out! Then I'm sure we'll be hearing LOTS o questions shortly...
I'll be sure to keep a helpful eye out for you at all appropriate forums when the time comes as we did the RS4 MTM 450HP kit in our "One Lap" car.
