need some help with leaking fluid woes....!!!
If its something simple like a hose, could i replace it with a Stainless steel line and be done with it?
seems to be coming from around the Aux. radiator. I have heard that some 20V owners have taken the Aux. radiator out altogether and plugged up the hoses without a large difference in operating temp.
Can anyone give me advice about eliminating the Aux. radiator?
-Thanks
If you loop them, the coolant passes though without being cooled fully and the car will overheat. If you plug them, coolant is forced through the main rad.
