OK I searched for Hours...
<center><img src="http://pictureposter.audiworld.com/51276/drway.jpg"></center><p>What is the wheel weight on these 16x17 competitions? Just figuring out my current tire weighs 20LBS and the new rims will be be 19.6 so if I want to stay lighter I can go with Kumho ASX @ 21LBS or not lighter..which I guess is a bad idea.. the fat heavy avons @ 23LBS.On another subject... I guess the 5mm difference 37 to 42ET and the tire width 205 to 215 will hopefully cancel each other out.Is this correct? OH... I finally got my centering rings from TR and I am almost ready to roll
Going with 5mm more positive offset and 10mm more tire width will move the inside sidewall....
of the tire 10mm closer to the centerline of the car, which may or may not cause rubbing issues with the tie-rod end. I don't think it would, but you'd better measure your current clearance before buying.
You're right that the outside sidewall of the tire will end up in the same place, so you shouldn't rub the fender.
All this assumes tire sizes are exact, which they aren't.
All in all, I'd avoid wheels with more positive offset, since it reduces the track of your car and hence hurts handling. 10mm is no big deal for street driving, but if you drive aggressively more track is better.
**** I got 225/45's on my 17x8 with 45et!
I came really close to the tie-rod in the front of my FWD but it was not rubbing, just came too close for comfort. So I bought some spacers, made it looks like the hotness plus some added mental security.
No Bozos!
Lighter tires = lighter tires
Lighter isn't necessarily a good thing(not necessarily a bad thing either). You want a good quality tire. A heavier tire indeed had implications on rotational mass, but the tradeoff is a much more durable tire(hopefully).
