quick tranny mount question
before i get started on this job, I somewhat know you need to remove the heat sheilds around the cats, question is what chance could the bolts bolts break, and do you need to remove any exhaust or can you get to these? I assume they are more towards the front and that the cats won't be an issue, any pointers?
went through search, didnt learn much
ironically the only post that gave me an idea was one of yours with a shot of the underneath.
I ran across this and I didnt make sense, least what i could tell on the b4:
For the snub, you gotta take the bumper, front crossmember, and a few other things off. I welded a peice of 3" exhaust pipe into the spot where the snub rests, restricting it's movement a bit more than stock. I did notice a difference when I did it long ago.
it doesnt look that difficult, i can see bolts where the metal bracket goes from the bumper to the engine with I guess the snub is inside this?
I don't think you have to take the bumper and crossmember off on a B4 for the snub
But I have to admit, the one time I looked at it I found I didn't have the proper sized wrench and my socket wrench didn't fit up there so I put it off for another day.
There are plenty of short write-ups on it.
yeah, I'm going.
Ticket face value was only $150, but...<ul><li><a href="https://forums.audiworld.com/other/msgs/2925381.phtml">it's not what you know, it's who</a></li></ul>
Who wrote that post?
For the search I typed in "gearbox mounts" and 67 items came up.....
1. Re: engine and tranny mounts [2]
The APR snub I have on my 93 fits inside its recess very snuggly! The only movement it allows is in the deflection of the material itself, which is very little. The mod you done on your 88, I performed a simular one on my 86 Coupe. I used a "U" clamp to...
https://forums.audiworld.com/9080/msgs/39832.phtml (text/html) Sun, 01 Sep 2002 03:16:28 GMT, 968 bytes
Audiworld > Forums > Audi 90 / 80 / Coupe quattro / Cabriolet
2. Re: gearbox mounts [2]
No need for the $30 bracket on the front snub. The 2 gearbox mounts are 8A0 399 151 D BONDED RUBBER MOUNTING Call my friend "Rod" at TPC there in California. Tell him Mike sent you! :O) 1-800-472-1144 He'll sell you the mounts for less than the dealersh...
https://forums.audiworld.com/9080/msgs/42165.phtml (text/html) Wed, 18 Sep 2002 16:01:56 GMT, 385 bytes
3. Re: The job [2]
The hardest part is getting all the parts from a "reputable" salvage yard. Then getting them in a condition which only requires a minor cleanup or rebuild(seals-gaskets)! Preferbly you want to get them from a donor Audi which was involved in a rear end c...
https://forums.audiworld.com/9080/msgs/12300.phtml (text/html) Mon, 31 Dec 2001 18:39:45 GMT, 6037 bytes
4. Re: Engine mounts [2]
Items 5 & 6 They hold your engine in place, along with the 3 other mounts. They primarily hold the engine from moving "up & down".(vertical axis) ;O) The front snub & 2 gearbox mounts allow the engine to "tee-ter-totter" on the 2 engine mounts! If you w...
https://forums.audiworld.com/9080/msgs/42056.phtml (text/html) Wed, 18 Sep 2002 01:51:36 GMT, 865 bytes
5. Engine mount rarely, if ever go bad. Front snub & gearbox mounts do! ;O) [2]
Did you change your gearbox mounts, when you installed the APR snub? If not, I can say, the APR will excellerate the wear, on your OEM gearbox mounts! BTDT! ;O)...
https://forums.audiworld.com/9080/msgs/212112.phtml (text/html) Wed, 21 Jul 2004 21:47:42 GMT, 334 bytes
6. Re: audi9490! [2]
What condition is the front snub mount in? The 2 side gearbox mounts? Personally, I dont think its your motor mounts!;O) I think its your 1 front & 2 gearbox mounts!...
https://forums.audiworld.com/9080/msgs/41983.phtml (text/html) Tue, 17 Sep 2002 18:00:56 GMT, 288 bytes
7. Re: Side gearbox mounts [2]
I just replaced mine! They simply "un-bolt"! You can get a wrench on the upper portion of the bolts via the same hole the axle runs through. I used a jack on the aft portion of the gearbox to support the gearbox while changing the 2 mounts. Very easy jo...
https://forums.audiworld.com/9080/msgs/42050.phtml (text/html) Wed, 18 Sep 2002 01:23:54 GMT, 487 bytes
8. I called them and I asked for the prices for gearbox mounts and they... [2]
thought I wanted a shift ****?!! And I told them that I wanted a gearbox MOUNT and they gave me the prices for an engine mount ($173.80). Is there a part number that I can tell them? And as for the front snub, there is a chunk of the rubber missing. I'm...
https://forums.audiworld.com/9080/msgs/42143.phtml (text/html) Wed, 18 Sep 2002 14:37:22 GMT, 829 bytes
9. Re: Side gearbox mounts [2]
I've got to do the same on my mounts and the general precedure seems to be jack the front of the car up on axle stands and then support the gearbox/engine with jack or stands and then remove the bolts going through the mounts. How you get access to the...
https://forums.audiworld.com/9080/msgs/42048.phtml (text/html) Wed, 18 Sep 2002 01:17:54 GMT, 468 bytes
10. Possible worn shift linkage, or worn gearbox mounts. [2]
There are actually 3 mounts, which if worn, can effect shifting considerably. The 2 on either side of the gearbox items 15 & 32 and the front engine mount, item 17 The shift mechanism has a rubber bushing at one end which can wear and also cause shift pr...
https://forums.audiworld.com/9080/msgs/11761.phtml (text/html) Sat, 22 Dec 2001 19:49:19 GMT, 646 bytes
11. Gearbox mounts are on eather side(L&R) of the gearbox. [2]
Next to the cats, silver looking thing, is the mounts heat-shield. They are near the lower "A" arm aft bushing....
https://forums.audiworld.com/9080/msgs/204545.phtml (text/html) Tue, 22 Jun 2004 14:51:20 GMT, 339 bytes
12. Possibly gearbox mounts? Shift linkage? Hows the oil level in the gearbox? [2]
https://forums.audiworld.com/9080/msgs/82736.phtml (text/html) Wed, 02 Apr 2003 19:04:27 GMT, 171 bytes
13. Re: Similar problem at 1200 rpm- Visually inspect your gearbox mounts......... [2]
by removing them from the car. They unbolt. Mine were "shot" but you couldnt tell until they were removed. I suspected they were bad because while backing up my exhaust would hit the underside of the car. The mounts can be totally shot, and support the...
https://forums.audiworld.com/9080/msgs/53111.phtml (text/html) Sun, 10 Nov 2002 11:47:17 GMT, 606 bytes
14. The 2 mains on the side, front snub, 2 gearbox mounts. Sounds like....... [2]
your front snub & 2 gearbox mounts are bad/loose?...
https://forums.audiworld.com/9080/msgs/204394.phtml (text/html) Tue, 22 Jun 2004 02:21:13 GMT, 223 bytes
15. Re: Possible worn shift linkage, or worn gearbox mounts. [2]
Thanks for the information MikTip. I will check things when I return from vacation....
https://forums.audiworld.com/9080/msgs/11763.phtml (text/html) Sat, 22 Dec 2001 20:31:25 GMT, 234 bytes
16. Side gearbox mounts [2]
What's it take to replace these? Would the engine need to be craned out? What about the front snub mount? I found a picture of these thingies using the search; they're useful but I'm still drawing blanks. Any help? Thanks. ...
https://forums.audiworld.com/9080/msgs/42035.phtml (text/html) Tue, 17 Sep 2002 22:46:54 GMT, 344 bytes
17. Re: Gearbox mounts [2]
Items 15 & 32. They work hand in hand with the front snub mount to limit engine movement under acceleration & braking! ;O)...
https://forums.audiworld.com/9080/msgs/42055.phtml (text/html) Wed, 18 Sep 2002 01:42:22 GMT, 321 bytes
18. Remember, the APR snub will reveal worn gearbox mounts! ;O) [2]
Best thing to do is replace them too! ;O)...
https://forums.audiworld.com/9080/msgs/98039.phtml (text/html) Wed, 18 Jun 2003 09:38:17 GMT, 196 bytes
19. Re: Remember, the APR snub will reveal worn gearbox mounts! ;O) [2]
Thanks, I think I'll replace them at the same time. Just waiting for my Bentley to come back, I sent it back to Bentley for the updated version. 93 90Q...
https://forums.audiworld.com/9080/msgs/98076.phtml (text/html) Wed, 18 Jun 2003 11:29:56 GMT, 317 bytes
20. Take a good look at the shift linkage & gearbox mounts for wear ;O) [2]
https://forums.audiworld.com/9080/msgs/114614.phtml (text/html) Wed, 27 Aug 2003 11:12:56 GMT, 167 bytes
21. Take a close look at your front snub and gearbox mounts. ;O) [2]
https://forums.audiworld.com/9080/msgs/115480.phtml (text/html) Mon, 01 Sep 2003 12:21:39 GMT, 156 bytes
22. Whats your gearbox mounts look like? ;O) [2]
https://forums.audiworld.com/9080/msgs/195323.phtml (text/html) Fri, 21 May 2004 01:45:33 GMT, 136 bytes
23. Re: What max hp can the stock mpi system handle on the V6? [2]
The "stock" MPI system does fairly well up to around 240HP. The problem is not the equipment, but more the programming. As the added air & fuel requirements are not programmed into the computer for it to react correctly. The MAF can be tweeked, along wi...
https://forums.audiworld.com/9080/msgs/9222.phtml (text/html) Fri, 23 Nov 2001 05:45:50 GMT, 895 bytes
24. Re: $1200 will cover everything under the moon and.. [2]
You write as if you've done the Auto-2-manual swap! ;o) A person maybe able to get away with the swap for $1200, but first they will need to do the work themselves! How many here are up to that trick? ;o) Audi dealership mechanics charge $65 an hour. Av...
https://forums.audiworld.com/9080/msgs/41177.phtml (text/html) Wed, 11 Sep 2002 17:44:08 GMT, 2528 bytes
25. Re: Trans problems [2]
Could be any number of things! ;o) Could be the shift linkage? Could be the gearbox mounts? Could be the engine mounts, including the front one. Could be the clutch? Could be the gearbox itself? Basically its a process of elimination, to determine the e...
https://forums.audiworld.com/9080/msgs/37184.phtml (text/html) Thu, 08 Aug 2002 08:38:34 GMT, 602 bytes
26. Re: ugh. [2]
Not intending to add insult to injury: Ya might as well do all the gearbox seals too, while its out of the car, and their very easy to get at! ;o) To do the rear seal, the flywheel needs to come off, so your gonna need "new" flywheel bolts. Reusing to o...
https://forums.audiworld.com/9080/msgs/35217.phtml (text/html) Thu, 18 Jul 2002 14:18:04 GMT, 709 bytes
27. Re: shaking [2]
Placing the drive in "N" sort of the disconnects the transmission/gearbox from the engine. You could say the vibration is caused by the gearbox, since the engine reved without vibration. I would take a close look at the 2 gearbox/transmission mounts, st...
https://forums.audiworld.com/9080/msgs/53597.phtml (text/html) Wed, 13 Nov 2002 09:04:31 GMT, 481 bytes
28. Re: Engine mounts [2]
The engine is actually suppose to move somewhat in the engine compartment!;o) Exactly how much does it move & in what direction, upon acceleration? Have you looked closely at the front snub mount? How about the 2 rear gearbox mounts? You may not have ba...
https://forums.audiworld.com/9080/msgs/41971.phtml (text/html) Tue, 17 Sep 2002 17:36:43 GMT, 455 bytes
29. Re: I did the engine mounts when i got my car about a year ago.. [2]
along with the gearbox mounts... My car had done 180000km's at the time and had a bad resonance around 3000rpm, changing the mounts has helped a bit... That drivers side mount (RHD) is an absolute C#$% to get out!!! Trent...
https://forums.audiworld.com/9080/msgs/40646.phtml (text/html) Sat, 07 Sep 2002 23:47:43 GMT, 392 bytes
30. Going after the T-mounts today! ;O) [2]
My gearbox mounts are showing their age. Time to replace with Mo'-better ones! Supposedly these newer ones are more stronger, & flex less. Should be ideal with the APR front snub I have! ;O)...
https://forums.audiworld.com/9080/msgs/39756.phtml (text/html) Sat, 31 Aug 2002 05:02:20 GMT, 416 bytes
31. Re: Pictures of the mounts [2]
They look normal! What condition are the 2 gearbox mounts in?...
https://forums.audiworld.com/9080/msgs/42267.phtml (text/html) Thu, 19 Sep 2002 02:18:06 GMT, 186 bytes
32. You need an APR front snub mount! ;O) [2]
I have one on my 90, & it does what it claims! However be advised you need to make sure your 2 side gearbox mounts are good! As the beefed up front snub will transfer those forces to the remaining attach points! ;O) Engine mounts 2!...
https://forums.audiworld.com/9080/msgs/39754.phtml (text/html) Sat, 31 Aug 2002 03:01:15 GMT, 464 bytes
33. Re: [2]
I think the engine moves a little too freely. I wouldn't call it a "slight bit"--There are 2 gearbox mounts+1 front mount? (these are not the 3 engine mounts right?) I might as well replace all 3 at the same time. Is this a common problem Mike; what cau...
https://forums.audiworld.com/9080/msgs/41997.phtml (text/html) Tue, 17 Sep 2002 18:34:33 GMT, 439 bytes
34. Re: 1st Gear [2]
Is designed to be shifted into when the car has nearly stopped rolling! You will find attempts to shift into first above certain mph's, is next to impossible. This is just a fact, inherant of the design. "Forceing" the shifter into 1st gear, will cause...
https://forums.audiworld.com/9080/msgs/18278.phtml (text/html) Fri, 22 Feb 2002 00:19:57 GMT, 593 bytes
35. Re: APR snub engine mount question... [2]
>You installed this mount when you switched transmission to manual, right? Yes >What are your impressions? Like it very much! >Does it work as advertised? Yes. >How difficult was the installation? Unbolt & rebolt front snub-holder! ) >90s, only A4. Di...
https://forums.audiworld.com/9080/msgs/30783.phtml (text/html) Sat, 01 Jun 2002 19:45:57 GMT, 584 bytes
36. Re: Alex! [2]
Any word on the A4 gearbox mounts? ;o)...
https://forums.audiworld.com/9080/msgs/41312.phtml (text/html) Thu, 12 Sep 2002 15:50:24 GMT, 143 bytes
37. Re: You're right? [2]
Right about which one? ) The front mount? The engine is suppose to move a slight bit, but if your front snub is bad, or gone, it will move much more! Plus more freely if the 2 gearbox mounts are bad! ;o)...
https://forums.audiworld.com/9080/msgs/41994.phtml (text/html) Tue, 17 Sep 2002 18:21:48 GMT, 325 bytes
38. Re: Dealer wanted $30 each for the ones I bought from them? [2]
$30 for the 2 gearbox mounts. Do you know for sure yours are bad?...
https://forums.audiworld.com/9080/msgs/42137.phtml (text/html) Wed, 18 Sep 2002 14:24:37 GMT, 221 bytes
39. Re: clunking over minor bumps is normally the upper strut bearings bad. [2]
during any throttle hiccups at low speed in low gear is usually the front engine mount or the 2 side gearbox mounts....
https://forums.audiworld.com/9080/msgs/49591.phtml (text/html) Thu, 24 Oct 2002 15:18:16 GMT, 283 bytes
40. Re: My old post............. [2]
"Check shifter linkage for slop & excessive wear" If you would of looked down 2 more posts: https://forums.audiworld.com/9080/msgs/72060.phtml Inferno wrote where to get the parts! ;O) I'd also check the gearbox mounts, and the front snub to see if they...
https://forums.audiworld.com/9080/msgs/104218.phtml (text/html) Tue, 15 Jul 2003 12:55:14 GMT, 470 bytes
3. Re: The job [2]
26. Re: ugh. [2]
27. Re: shaking [2]
33. Re: [2]
36. Re: Alex! [2]
oops, i searched for trans mounts......
anyhow, i am already in the process of doing it so its pointless now, and i already figured out the problems...as usual nothing come out easy
Hotrod008
Audi Original "S" Cars
05-23-2004 07:14 PM
