So fan speeds 1 and 2 dont work....but...
got my temp cluster used for $10 off ebay...
my setup was klinda crazy, if I pulled the switch out and plgged it in, it worked fine, but installed it didn't work. it also 'looked' perfect. I finally said f-it and installed the older used ebay one....everything works 100% now.
Re: So fan speeds 1 and 2 dont work....but...
Blower motor resistor. apeeds 3/4 go throught the resistor in the blower itself.... 1/2 has a resistor behind the glove boxe in the 90. Just replaced mine in my 1995.
The switch was my problem
After I changed the resitors. Got all from the salvage yard for $30. Used switch is kinda bunk though. A year later, speed 3 is intermittant. I think I'll go over the original one and see what was wrong. Its only a cam switch and copper contacts. Allow some time to change the switch, those cables are tough to get off and back on.
This was on a 1988 90.
Dave
Dave
papuc (MMI S4)
09-11-2008 11:54 AM
dassub
07-22-2008 12:45 PM
what would cause my electric Fan to turn off when I start the car? I installed a switch with a relay
S4@last!::Now B7 RS4
02-13-2005 04:05 PM
