Thermostat Where is it???
Re: it's in the middle-front of the block. conveniently hidden behind the timing belt.
Do you happen to have a page from a manual showing the exploded view, that can be e-mailed to me..
And thanks for the info so quickly.
YGM... best I can do, it's not the greatest diagram. You should really search this forum, you'll
definitely find something. In fact, pretty much for every question you can think of you should start by thoroughly searching our archives. Usually right off the bat we instruct every noob to make a good attempt before asking questions...mostly because whatever you'll come across is a generic problem that has been "solved" many many many times over.
so I've bailed you out this once, but in the future make a effort please & thank you.
here...
REMOVAL
Remove ribbed drive belt.
Loosen toothed timing belt as required (it is not necessary to remove toothed timing belt).
<a href="http://photobucket.com" target="_blank"><img src="http://i51.photobucket.com/albums/f400/Ashnjerm/62484198.gif" border="0" alt="Photo Sharing and Video Hosting at Photobucket"></a>
Unbolt thermostat housing and pull out from below toothed belt.
<a href="http://photobucket.com" target="_blank"><img src="http://i51.photobucket.com/albums/f400/Ashnjerm/62484199.gif" border="0" alt="Photo Sharing and Video Hosting at Photobucket"></a>
Installation position of thermostat.
The vent valve must be installed facing up (arrow).
INSTALLATION
Installation is the reverse of removal, noting the following:
Adjust tension of toothed timing belt.
INSTALLATION
about right here ;)
<center><img src="https://www.audiworld.com/tech/pics/eng102_TB038.jpg"></center><p>there is a write up on 20v.org to follow, and i covered it in my write up in the tech articles...search my friend.
ybot1973
10
03-15-2010 05:31 AM
koolhand
11-11-2006 11:30 AM
gogu
12
01-05-2005 04:04 AM
C5867
06-27-2003 04:14 PM
1986, 2000, 2004, 42, audi, cabrio, continental, diagram, housing, installation, lincoln, s4, thermostat
