Those cabbies with lowered suspension
Re: Those cabbies with lowered suspension
<center><img src="http://pictureposter.audiworld.com/76266/mycar1.jpg"></center><p>Ok 2bennet.com has a coil over system that you can have set with bilsteins or Koni shocks, priced a little above a grand. Tap1.com sells intrax springs with bilsteins also for around $800. Dont forget to look into the updated strut bushing. And H and R makes springs for your car also. Overall value vs. performance I would have to go with the coil overs. You can adjust them to whatever amount of inches you want, as apposed to progressive rate springs which I believe will drop the cabs 1.4 in the front and 1.6 in the rear. If you add the updated strut bushing it will push it another .25 inches all the way around.
dtompsett
03-20-2010 02:36 PM
Zzak
35
10-17-2003 07:03 AM
audifirst
09-20-2001 10:08 AM
