Transmission plans:
Transmission plans:
Here's what I would like to do within the next 2 months...
- Flush and refill with Redline MT90 (A friend did this on an A4 and said the difference was night/day)
- Linkage rebuild (see link)
-A4 tranny mounts
I'm going to put it up on a lift next weekend and take a closer look at the mounts and linkage bushings.
Mike<ul><li><a href="https://forums.audiworld.com/a4/msgs/1581653.phtml">https://forums.audiworld.com/a4/msgs/1581653.phtml</a</li></ul>
-A4 tranny mounts
I found MT90 too thin.........
Switched back to Mobil 1 75w-90.
The reason I say MT90 was too thin, is I could hear the gears in my gearbox whine. Plus shifting was very notchy.
Drained MT90, installed Mobil 1, synth, and my gearbox is smooth & no noises.
a few questions:
Easy to access the tranny? I'd be using jackstands, might be able to get access to a lift (probably not though). Is this something I could do in a driveway?
How do you get the old fluid out? (Is there a drain on the bottom or do you have to get it from the top?
Any special tools needed?
Thanks,
Mike
AWOT Axis of Evil #
Thanks,
Mike
AWOT Axis of Evil #
Re: I found MT90 too thin.........
I have read (do not remember where exactly) that only a GL4 rated transmission fluid should be used in the Audis, whereas the MOBIL 1 is a GL5 rated lubricant and should not be used because it eats away at the synchros in the transmission.
Might want to check into this further before problems arrise.
Just be sure to remove the TOP plug first...
...if you remove the bottom and drain the fluid, then the fill plug is siezed...you're screwed.
Also, I used redline in my CQ..and it was better during the cold mornings....but then I changed it to the stock stuff (G00500 ?) and it was AMAZINGLY better...like new, really. Just my two cents.
Tomasz@Startup
03-15-2008 09:33 AM
BigMouse
08-21-2005 02:20 PM
