what else beside the timing belt
Re: what else beside the timing belt
O2 sensors.
Valve guide seals if you are blowing blue smoke.
Fuel injectors if your engine is running like crap and/or blowing white smoke.
Catalytic converter.
Power steering related garbage.
vaccum lines (if you idle high or stall when idling)
EGR valve maybe? (clogged with soot)
Various motor, transmission, suspention mounts and bushings.
Tie rods, ball joints, wheel bearings.
Burnt out dashboard lightbulbs.
This is a list of common stuff that can go wrong in an older car. Not saying you should just replace stuff if it's not broken yet.
ok let me make it clear:
my cur runs perfect! better then some cars with 1/3 of its millage. even though i have a bit over 190k on it. Previous owner took care of this baby! I'm going to change timing belt just in case since there is no sticker on it. I don't want to change EVERYTHING, just things one should change!
thx
'93 90cs
thx
'93 90cs
blslhi
07-08-2005 08:36 AM
cougarbball310
03-18-2004 06:12 PM
lil'lgr
13
04-17-2002 08:55 AM
Liam in Montreal
10-12-2000 09:27 PM
