Who autocrosses their 90?
I am considering getting a 90 quattro for daily use and autocross. In my region this car ends up in H Stock which should make it pretty competitive.
I'd like to correspond with somebody who has set up this kind of car for autocross and/or track use.
Please respond to this thread with your year, model and usage so that I can develop some more specific queries.
Re: Who autocrosses their 90?
When I ran H Stock in the CQ back in the day, I finished mid-pack, after DNF'ing 3 or 6 runs (it was my very first driving event). I think if I had a better tire (was running D60A2 jlb's which are not so sticky H-rated M+S all seasons).
When I ran it in STX this past summer, I placed worse, due to not being able to set tire pressures, and I am also currently down on power. I think I could have gotten a mid to higher placement with proper tire pressures and a strong running engine.
Mods on the early 1990 CQ consist of 250 lb/in springs front, 300lb/in springs rear over Koni "Yellow" shocks set to 50% of their adjustment. Car also has a big brake setup from a 1997 993C2 and Stebro exhaust. Of questionable power increase is a Jamex lower airbox. Also trimmed some weight with an aftermarket B4 hood in steel (also have a glass fibre hood) and the S2 bumper.
I went this summer...
my 90 FWD did pretty well in H stock...I got beat by some kid in an avenger...but I felt as if the car handled very well and I would have done much better if I had tires that weren't so worn...
I have run STS class
I run this class because I wanted to run suspension and larger diameter wheels. This class allows this. It is basically a street mod class with dot tires rated at 150 or higher. cuatrokoop had to run STX because he was running big brakes.
I am also running S2 bumpers front and rear.
Re: I have run STS class
"cuatrokoop had to run STX because he was running big brakes"
Yup...I think I can stay in STX/M even after dropping in the 10vt, but I'm not sure, my book doesn't really cover it (I'm a bad SCCA member, haven't gotten the most up to date book for 2 years?). Hopefully I'll have everything ironed out with the car by next summer so I can find out...
Hey BigMouse - $30 to join, split $40 bucks worth fo rules ...
Course your car actually has a chance, mine would be more for novelty value, but maybe in the wet ...
There are sites for the SF clun at Cal Expo and McLelland !
brian@AutoSpeed-gt25
Mid Atlantic Discussion
10-27-2007 10:39 AM
Jeff_4000Q
11-16-2006 01:50 PM
eurotrippin'
03-01-2005 04:30 PM
