xpost:alignment hlp: my 90 stays straight on flat but is _very_ susceptible by uneven pavement.
thanks<ul><li><a href="https://forums.audiworld.com/suspension/threads/198.phtml#">CLICK</a></li></ul>
What about tie rod ends, control arm bushings...
...if your suspension isn't all up to par it can tend to pull and make the ride seem off over uneven terrain. Even bent wheels/crappy tires/tires with uneven wear/bad alignment can throw the ride off.
Replace any bad components, but your prob is all in those angles...
Caster is way low on both fronts, camber is out on all wheels. Car likes to go to the right on the uneven pavement???
Been out of the alignment business for 10 years, but the straight line tracking problem is due to the caster being out so far. The higher caster angle on the right front most likely causes a drift to that side.<ul><li><a href="http://www.familycar.com/alignment.htm">alignment 101</a></li></ul>
I just had strut mouts done, my control arm bushings 10 to 15 k old..and I had the rest of the stuff
looked over. However today simething died after hard braking. Front passanger wheel making a cracking noise on acceleration after hard braking, and going over a small speed bump.
Got it scheduled for Thursday...
A4xIV / Nadroj
09-10-2008 03:23 PM
kens4
13
10-25-2004 06:04 AM
CK NYoC
02-14-2004 04:04 AM
shehatezme
07-28-2003 06:00 AM
