Audi A1 Discussion forum for the Audi A1
A1clock spring nightmare!!!
Old 10-04-2018, 01:15 PM
Mill Lane's Avatar
Default A1clock spring nightmare!!!
Hi, I'm hoping someone here might be able to shed some light on this problem I'm having after replacing a clock spring on a customers 2011 A1 (8X0)
Its the first time I've used VCDS but after reading up in detail I think I did it correctly but now I've got more faults than when I started.
Initial scan:
Code:
Thursday,30,August,2018,12:29:24:47119
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 17.8.0.1 (x64)  HEX-V2 CB: 0.4401.4
Data version: 20170721 DS276.2
www.Ross-Tech.com
VIN: WAUZZZ8X5CB022228   License Plate: JODIE 1
Mileage: 55980km-34784mi   Repair Order:
Chassis Type: 8X-AU21 (8U0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 47 52 5F
VIN: WAUZZZ8X5CB022228   Mileage: 55980km-34784miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
Address 01: Engine (J623-CAYC)       Labels:. 03L-906-023-CAY.clb
   Part No SW: 03L 906 023 KQ    HW: 03L 906 023 KP
   Component: R4 1.6l TDI   H63 9978
   Revision: --H63---    Serial number:
   Coding: 00114016030501080000
   Shop #: WSC 00046 790 00000
   ASAM Dataset: EV_ECM16TDI02103L906023KQ 003015
   ROD: EV_ECM16TDI02103L906023KG.rod
   VCID: 7F580ABAE776FC0F220-802A
1 Fault Found:
7609 - Control Module 1 for Coolant Fan
          P1946 00 [101] - Defective
          Not Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 36262 km
                    Date: 2017.01.25
                    Time: 14:14:14
                    Engine speed: 1982.75 /min
                    Normed load value: 33.7 %
                    Vehicle speed: 106 km/h
                    Coolant temperature: 96 °C
                    Intake air temperature: 15 °C
                    Ambient air pressure: 1010 mbar
                    Voltage terminal 30: 14.456 V
                    Unlearning counter according OBD: 40
                    Sensor for temp after charge air cooler: raw value-TBA_MES: 15 °C
                    Sensor for engine block temperature: raw value-Coolant temperature: 96 °C
                    Coolant temperature at radiator outlet: actual value-TCO_2: 95 °C
                    Outside air temperature-Ambient temperature: 8.25 °C
                    Ambient air pressure-Ambient pressure: 1013.58 hPa
                    Coolant fan 1: activation-Radiator fan 1: activation: 17.2 %
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (J104)       Labels:. 6R0-907-37x-ESP82.clb
   Part No SW: 6R0 907 379 BB    HW: 6R0 907 379 AH
   Component: ESP8.2i front H07 0001
   Revision: --------
   Coding: 330448E9436F00B4CC2712E4C2D900920C00
   Shop #: WSC 00046 000 00000
   VCID: 7F580ABAE7B6FC0F220-802A
No fault code found.
Address 08: Auto HVAC        Labels: None
   Part No SW: 8X0 820 045 A    HW: 8X0 820 045 A
   Component: J255 Klima Manuell  0140
   Revision: 0000707S    Serial number: 03030005470664
   VCID: 343215969230EF578F2-8060
Address 09: Cent. Elect. (J519)       Labels:. 8X0-907-063.clb
   Part No SW: 8X0 907 063 G    HW: 8X0 907 063 G
   Component: BCM PQ35  M   110 0655
   Revision: 00110 AE
   Coding: 0E000A2CA805F100201841E020000154538B6C0A01CF4122DC0887830045
   VCID: 40DA4946DA8843F71BA-8014
   Subsystem 1 - Part No: 8X0 951 177
   Component: DWA-Sensor H0  H01 0020
   Subsystem 2 - Part No: 1K0 951 605 C
   Component: LIN BACKUP HO  H05 1501
1 Fault Found:
01502 - Bulb for Rear Fog; Left (L46)
            010 - Open or Short to Plus - Intermittent
             Freeze Frame:
                    Fault Status: 00101010
                    Fault Priority: 2
                    Fault Frequency: 254
                    Reset counter: 47
                    Mileage: 40118 km
                    Time Indication: 0
                    Date: 2017.11.02
                    Time: 19:02:42
             Freeze Frame:
                        Term 15 On
                    Voltage: 14.35 V
                        ON
                        ON
                        Term 50 On
                        OFF
                        OFF
Address 15: Airbags (J234)       Labels:| 8X0-959-655.clb
   Part No SW: 8X0 959 655 A    HW: 8X0 959 655 A
   Component: Airbag10.41   H04 0008
   Revision: --------    Serial number: 003JJ002XTZB
   Coding: 30314539303330303034554A305238583053
   ASAM Dataset: EV_Airba1041BPAAU210 001015
   ROD: EV_Airba1041BPAAU210.rod
   VCID: 48CA5166F2387BB7D3A-801C
   Crash sensor for side airbag: driver side:
   Serial number: 3554VRB405V0K4DICPCF
   Crash sensor for side airbag: front passenger side:
   Serial number: 3575HRB40570N3MG5O7J
   Crash sensor for front airbag: driver side:
   Serial number: 3585HRB40590N3MGCGJX
   Rear Impact Crash Sensor:
   Serial number: 3515ZRB40610IAMCC92B
1 Fault Found:
9437211 - Igniter for Driver's Airbag
          B1000 1B [137] - Resistance Too High
          MIL ON - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 51743 km
                    Date: 2018.06.03
                    Time: 15:00:43
Address 16: Steering wheel (J527)       Labels:| 8X0-953-569.clb
   Part No SW: 8X0 953 501 B    HW: 5K0 953 569 H
   Component: LENKS.MODUL   014 0140
   Revision: FF010016    Serial number: 20110729200828
   Coding: 1184004000
   ASAM Dataset: EV_VW360SteerWheelUDS A03004
   ROD: EV_VW360SteerWheelUDS.rod
   VCID: 392C24A2B9D2123F5C4-806C
1 Fault Found:
365080 - Controls in Steering Wheel
          U108E 00 [009] - No Communications
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 106
                    Mileage: 51743 km
                    Date: 2018.06.03
                    Time: 15:00:41
Address 17: Instruments (J285)       Labels:| 8X0-920-xxx-17.clb
   Part No SW: 8X0 920 980 D    HW: 8X0 920 980 D
   Component: KOMBI_MEDIUM  H03 0179
   Serial number: 00000000000000
   Coding: 41DE00
   ASAM Dataset: EV_Kombi_UDS_VDD_AU10 A04390
   ROD: EV_Kombi_UDS_VDD_AU10.rod
   VCID: 40DA4946DA0843F71BA-8014
Address 19: CAN Gateway (J533)       Labels: 8X0-907-468.clb
   Part No SW: 8U0 907 468 A    HW: 8U0 907 468 A
   Component: GAT 4CAN 1L M H10 0044
   Revision: 1P040023    Serial number: 2341P1172101BE
   Coding: FBCF005A000100010153
   Subsystem 1 - Part No SW: 8K0 915 181 H    HW: 8K0 915 181 H
   Component: J367-BDM  H07 0171
   Serial number: 00000000007100802462
   Subsystem 2 - Part No SW: 8K0 959 663 F    HW: 8K0 959 663
   Component: J532_DCDCStab  H18 0018
   Serial number: 10061100000000000091
Address 25: Immobilizer (J334)       Labels:| 5K0-920-xxx-25.clb
   Component: IMMO          H03 0179
   Serial number:
   Coding: 000002
   ASAM Dataset: EV_Immo_UDS_VDD_AU10 A04110
   ROD: EV_Immo_UDS_VDD_AU10.rod
Address 42: Door Elect, Driver (J386)       Labels:. 8X0-959-793.clb
   Part No SW: 8X0 959 793 D    HW: 8X0 959 793 D
   Component: TSG FA        H09 0409
   Revision: --------    Serial number: --------------
   Coding: 011E02200101000100
   VCID: 4EC6677E10DCA587996-801A
Address 44: Steering Assist        Labels: 6Q0-423-156.clb
   Part No: 6R0 423 156 B
   Component: LenkhilfeTRW        V277
   Coding: 11251
   Shop #: WSC 00046
   VCID: 2F381AFA7E56CC8FF20-807A
Address 47: Sound System (J525)       Labels: Redir Fail!
   Part No SW: 8X0 035 223 C    HW: 8X0 035 223 B
   Component: BOSE G3 A1Q3  H04 0130
   Revision: CK004200    Serial number: 00000000001521
   Coding: 010000
   VCID: 323E138E6424E1679DE-8066
Address 52: Door Elect, Pass. (J387)       Labels:. 8X0-959-792.clb
   Part No SW: 8X0 959 792 D    HW: 8X0 959 792 D
   Component: TSG BF        H09 0409
   VCID: 4DC460721DDA9E9FE0C-8018
Address 5F: Information Electr. (J794)       Labels: None
   Part No SW: 8X0 035 193 E    HW: 8X0 035 193 C
   Component: RMC Cnct Nav  H51 0775
   Coding: 01010000008051070023000103020100000000
   VCID: 3A2E3BAEBC54192755E-806E
   Subsystem 1 - Part No SW: 8X0 919 603     HW: 8X0 919 603
   Component: DU6 Basic  H42 0084
   Serial number: 9462HQ0B0126704
End----------(Elapsed Time: 01:04, VBatt start/end: 12.0V/12.1V)-----------
this and reading up on other similar problems led me to diagnose the clock spring as the issue, replaced and coded which resulted in:
Code:
Tuesday,02,October,2018,16:56:40:47119
www.Ross-Tech.com
VIN: WAUZZZ8X5CB022228   License Plate: JODIE2
Mileage: 56930km-35374mi   Repair Order:
VIN: WAUZZZ8X5CB022228   Mileage: 56930km-35374miles
03-ABS Brakes -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 36262 km
                    Date: 2017.01.25
                    Time: 14:14:14
   Revision: --------
1 Fault Found:
00778 - Steering Angle Sensor (G85)
            005 - No or Incorrect Basic Setting / Adaptation
             Freeze Frame:
                    Fault Status: 01100101
                    Fault Priority: 0
                    Fault Frequency: 2
                    Reset counter: 48
                    Mileage: 56935 km
                    Time Indication: 0
                    Date: 2018.10.02
                    Time: 00:02:54
             Freeze Frame:
                    Hex Value: 0x0007
                    Hex Value: 0x0002
                    Hex Value: 0x1051
                    Hex Value: 0x1B87
                    Hex Value: 0x00FF
                    Hex Value: 0x7F7F
                    Hex Value: 0x7F00
   Revision: 00110 AE
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 2
                    Reset counter: 55
                    Mileage: 40118 km
                    Time Indication: 0
                    Date: 2017.11.02
                    Time: 19:02:42
             Freeze Frame:
                        Term 15 On
                    Voltage: 14.35 V
                        ON
                        ON
                        Term 50 On
                        OFF
                        OFF
1 Fault Found:
          B1000 1B [136] - Resistance Too High
          MIL ON - Intermittent - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 51743 km
                    Date: 2018.06.03
                    Time: 15:00:43
Address 16: Steering wheel (J527)       Labels:| 5K0-953-569.clb
   Part No SW: 5K0 953 569 AL    HW: 5K0 953 569 AL
   Component: LENKS.MODUL   016 0180
   Revision: --X01---    Serial number: 20180415200305
   Coding: 1184004000
   Shop #: WSC 01286 386 08256
   VCID: 025E834E948491E74DE-8056
   Multifunction steering wheel control module:
   Subsystem 1 - Part No SW: 4G0 951 528 C    HW: 4G0 951 528 C
   Component: E221 - MFL  H07 0009
   Serial number: 31 03 2011  11122738
13 Faults Found:
0516 - Databus
          U1121 00 [009] - Missing Message
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 48
                    Mileage: 56935 km
                    Date: 2018.10.02
                    Time: 00:02:59
147462 - Terminal 15
          B1148 12 [009] - Short to Plus
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
226827 - Turn Signal Switch
          B1144 13 [008] - Open Circuit
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 6
226839 - Turn Signal Switch
          B1144 11 [009] - Short to Ground
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 48
227339 - Windshield Wiper Switch
          B1145 13 [008] - Open Circuit
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 5
227355 - Windshield Wiper/Washer Switch
          B1149 13 [008] - Open Circuit
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 9
                    Reset counter: 88
229127 - Cruise Control Switch
          B1154 11 [009] - Short to Ground
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
229147 - Cruise Control Switch
          B1154 13 [009] - Open Circuit
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
332660 - Databus
          U1121 00 [008] - Missing Message
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 88
342020 - Comfort System CAN Bus (SAE Medium Speed Bus)
          U0011 00 [008] - Performance
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
          U108E 00 [008] - No Communications
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 2
617736 - Selector Lever Park Position Lock Switch
          B1162 29 [008] - Signal Implausible
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 2
1140738 - Steering angle sensor
          B1168 54 [009] - Missing Calibration / Basic Setting
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 2
                    UBat: 13.10 V
                    MC1 interner Fehlercode: 0
                    MC2 interner Fehlercode: 0
   Coding: 41DE00
   Serial number:
   Coding: 000002
   Coding: 11251
   Shop #: WSC 00046
   Coding: 010000
1 Fault Found:
02111 - Motor for Window Regulator
            005 - No or Incorrect Basic Setting / Adaptation - Intermittent
             Freeze Frame:
                    Fault Status: 00100101
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 71
                    Mileage: 56556 km
                    Time Indication: 0
                    Date: 2018.09.15
                    Time: 02:31:45
End----------(Elapsed Time: 00:59, VBatt start/end: 12.2V/12.2V)-----------
not what i needed!!!! after calming down from the panic that my first coding job had cost me £250 I've sort of got my head round VCDS coding and think I did what i was supposed to??
what i don't understand and think this is where the problem lies is in the first scan the fault is registered with Part No: SW: 8X0 953 501 B (switch stalks) HW: 5K0 953 569 H (clock spring)
in the second scan:
Part No SW: 5K0 953 569 AL HW: 5K0 953 569 AL (part no of the replacement clock spring)
I've come to the conclusion that perhaps the clock spring originally came as part of the switch stalk assembly and is the only programmable part of that joint assembly, is that correct??
Am I missing something? I read somewhere something about dealer codes but to be honest its all very alien to me, Ive tried posting on the rosstech forum but noones offered me a possible solution.
Ive used a genuine part and licensed copy of VCDS
I've done continuity tests on both units and the original clock spring definitely has a fault
thanks for your time, I hope someone can help..........
Old 10-12-2018, 02:59 PM
Head Cat Herder
Kris Hansen's Avatar
My guess is you have a wiring issue, along with parts issues. I didn't think you could code some parts with VCDS, have you checked with a dealer to see what they say?
kingcezar1992
A6 (C7 Platform) Discussion
13
03-05-2020 08:44 AM
Tendai Kufandirori
A4 (B8 Platform) Discussion
08-23-2019 09:54 PM
RodriguesV
01-06-2018 08:21 AM
Kebo
07-13-2017 08:55 AM
jnins5
02-14-2016 01:10 AM
Quick Reply: A1clock spring nightmare!!!
