Audi A2 Discussion forum for the Audi A2
Seafoam A2
Old 10-02-2011, 01:56 PM
chrisb1976's Avatar
Default Seafoam A2
Hi all,
I'd like to use Seafoam to remove carbon deposits in my engine.
The seafoam website says "Locate a vacuum line that you are certain DISTRIBUTES EVENLY TO ALL CYLINDERS. On many vehicles the easiest option is taking the vacuum line from your brake booster PCV"
Where's the Brake Booster PVC or a good vacuum hose to use on an A2 FSI? A picture would really help.
Thanks
Old 07-26-2012, 06:38 AM
Jusforfun's Avatar
It is the vacuum line from engine to the large chamber behind the Brake master cylinder. You should also be able to find an input like a tyre tube valve with a cap on it somewhere on the inlet manifold.
Old 11-24-2012, 06:07 AM
tofast2belast's Avatar
make sure not to mistake the one for the fuel rail. it also looks like a valve stem port. unless you want gas in your face.
i got the spray can seafoam and put the line in the throttle body inlet and put the charge pipe back on over it and sprayed it in that way.
bavareze
10
06-11-2014 07:12 AM
DE
12v V6 Discussion
10-07-2012 06:04 PM
tela
Audi 100 / A6 (C4 Platform)
9
08-17-2008 03:50 PM
VIPSA
12-06-2003 10:29 AM
Colonel Bogey
07-17-2000 05:26 PM
Quick Reply: Seafoam A2
