Audi A3 / S3 / RS 3 Discussion forum for the 8L and 8P Audi A3 S3 and RS3
Engine Code
Old Dec 10, 2003 | 02:37 AM
g4ryhunt's Avatar
New Member
Default Engine Code
Where do I find the engine code on a W reg 1.8T quattro. I know a guy selling an Air Mass meter on the cheap and I was told that it would be compatible with all A3/A4/A6 1.8 turbo engines with an 'AEB' engine code
Old Dec 10, 2003 | 04:16 AM
Dallan's Avatar
New Member
Default Re: Engine Code
Do you have the service history booklet? There should be a sticker inside the front cover giving the spec of your particular model.
There should also be a duplicate sticker in the boot. Lift the carpet and on the right of the spare wheel well you should see a similar sticker giving model details - You may need an Audi/VW service technician to help decode the letter/number combinations but the engine type should be there.
D.
Old Dec 11, 2003 | 06:47 PM
HTC's Avatar
HTC
New Member
If you look at the front left hand side of the head you will see the three engine code letters stamped on a flat piece. You should be able to see it without removing the plastic cover.
jeffrwatkins
May 14, 2010 05:11 AM
AznA408(NikkaPuhlez)
Sep 25, 2005 07:48 PM
vErSeTiLe
Jun 3, 2003 02:13 PM
cpuckrun
Apr 8, 2003 08:23 PM
Andrewembassy
Feb 6, 2003 07:02 PM
