Height Adjustment on coilovers
Is there a norm for the method used to adjust ride height on coilovers? Do they all generally have the big nut below the bottom of the spring that's turned with what looks like an oversided, non-adjustable crescent wrench? That method of adjusting the ride height always seems to entail having to jack the one wheel off the ground to fully extend the assembly, remove the tire and then make your adjustments.
Do some manufacturers implement other methods such as from under the hood like how I so far understand some manufacturers provide dampening adjustments?
Ride height and dampener stiffness is 2 different things...
Coilovers are made so you can perfectly corner balance your car and set at the desired height. Dampener adjustments are there to simply complement the adjustability of the ride height and spring rates. Coilovers are not made for good looks and for playing with them too often as it may disturb the balance of your car and cause you to something silly which otherwise you wouldn't if you had stock suspension.
Have a professional shop setup your system and leave it at that.
But what about wanting to change for the seasons. Lower in summer, Higher in the winter.
That would seem to be one of the biggest reasons I would buy a adjustable system. 2 Changes a year. Are they made for that?
yes
most use a nut / wrench system to raise and lower.
<img src="http://pictureposter.audiworld.com/49459/kwrearperch.jpg">
Also, since COs (at least KW) have smaller shock towers, they still have decent piston travel once the car is lowered. When lowering on stock the shock is always partially compressed beyond the norm.
<img src="http://pictureposter.audiworld.com/49459/oemnonsportvkwco.jpg">
some info here:<ul><li><a href="http://www.eurotuner.com/howto/26598/">http://www.eurotuner.com/howto/26598/</a</li></ul>
Technically you could though i don't see a great benfit of raising the car in the winter...
I've driven lowered cars in the Chicago winters without any problems...unless you like going offroad, which I doubt you will with a FWD Audi, I don't see a need to raise them. Set the height you like and keep it would be my word, but to each his own.
Changing the ride height would be crucial in winter. You can't always see how
high the curbs is you are park in front of. Or sometimes you cant see them at all. I would hate to force my car on a curb becouse I couldent see the thing.
What about going offroad once a year?
Like I know this secret hot spring oasis in Death Valley. To get to it, you need sufficient clearance. I'd go there once a year, the rest of the year I'd be low for on-road.
What is a clearance range I can expect from a CO setup?
Phil@BSH
39
02-25-2008 05:37 AM
Phil@BSH
Audi A3 / S3 / RS 3
02-21-2008 03:19 PM
Slave IV
Suspension Tuning Discussion
07-05-2007 05:05 PM
CZA4
08-06-2004 05:59 PM
Niko_F
02-07-2003 07:38 PM
