Audi A3 / S3 / RS 3 Discussion forum for the 8L and 8P Audi A3 S3 and RS3
Old 08-09-2016, 11:41 AM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Audi A3 Tire Repair and Maintenance
Print Wikipost
Tire Pressure Monitoring System
Old 10-30-2009, 01:23 PM
penskeford's Avatar
Default Tire Pressure Monitoring System
2009 A3 6 speed manual 2.0 T I got the yellow tyre warning about 3 weeks ago and it simply will not go away. Can you disable this?
Old 10-30-2009, 01:24 PM
penskeford's Avatar
Huh?
Old 11-05-2009, 05:26 PM
MonthOLDpickle's Avatar
I know this is obvious, but did you put some more air in your tires?
Old 11-09-2009, 09:12 AM
MaWeiTao's Avatar
You deactivate the warning by inflating your tires to the proper pressure.
If the tires are properly inflated then maybe there's a problem with a sensor.
I sure hope you've already checked the pressure and aren't driving around on underinflated tires.
Old 11-19-2009, 06:37 PM
kill4surf's Avatar
I have an 09 A3 and have the same issue. We have set the tire pressure correctly and the light will not go off. Tried clearing it with a VAG COM and couldn't do it. Taking it to dealer to have them take care of it. They said it should take about 20 minutes and it has been a common problem.
Old 11-23-2009, 09:02 AM
a3_in_va's Avatar
Default Just to cover all bases...
Assume you did the press-and-hold on the light itself? Or maybe is this more serious...
Old 11-23-2009, 09:35 PM
BBC
BBC's Avatar
The system can be completely disabled, you must remove the fuse from the module, or if fuse runs multiple things you must disconnect module behind indtrument cluster. Then Code cluster for no TPMS, and unistall from gateway installation list. Voila no TPMS in any A3, or new TT.
Old 10-05-2014, 07:21 PM
OldSkewS4's Avatar
Any idea where the module is located on 2009 A3's?
Old 10-14-2014, 06:05 AM
Dr_Evil's Avatar
On my 2012 A3 there is no module. It is a passive system that works with the anti-lock brake system to calculate tire diameter and circumference. When the pressure changes the circumference changes. Otherwise the active system is located behind the glove box.
Old 10-14-2014, 12:12 PM
sailor99's Avatar
Maybe I am not understanding the issue but my experience has been that you re-set the pressures for the tire monitoring system in the on board computer. You don't actually input a number, just re-set the system to the current pressures. Pardon me if I am not understanding.
Q5 TDI
Audi A3 / S3 / RS 3
08-25-2014 04:56 AM
eggyacid
Q7 MK 1 Discussion
01-28-2012 02:17 PM
spaniardone
11-04-2009 08:19 AM
AUDIFAN008
RS4 (B7 Platform) Discussion
9
10-11-2006 02:20 PM
Emauss
17
07-09-2006 04:20 AM
Quick Reply: Tire Pressure Monitoring System
