How can I install a hitch on my 2015 A3?
#11
I just installed a Curt 113992 class 1 hitch on my 2016 A3 Quattro Premium Plus. The install was very easy. The only tough part was clearing the goop off the frame holes to fit the bolts through and the wiring. I couldn't get the curt wiring harness recommended to work so I wired my 4 wires directly to the tail lights and it works great. My trailer only has LEDs so the draw is minimal.
It's amazing how little info is out there about the 2015 A3's. There must be a conspiracy!
#12
I am trying to do the same thing for my car. I wonder if you or anyone can explain what wires to connect to? I can't get my tail lights off even after removing the two screws, so I can't use a multimeter on the connector to figure out which wires to tap. Also I can see no other connectors behind the trunk panels that I could open to check.
I found that information from reading vwvortex forum and specifically the information posted from this user: VWVortex.com - CURT Manufacturing has Released the A3 Sedan Hitch Receiver
and used that and the graphic diagram (see here) he provided of the wiring to show the u-haul installer in my area and got it installed on my 2015 A3.
#14
I finally tried this out using a Curt 59236 converter (the one specified for this car by etrailer IIRC), but it didn't work for me. Trailer brakes and tail lights look OK, and the right turn signal too. But when I try the left turn signal, the trailer right turn signal is the one that flashes. The left signal gives a weak flash now and then.
It's not entirely clear that the thread linked to was 100% successful either. The writer said he just needed brakes...
(R)S4 SmokedU /-///
9
09-05-2006 07:22 PM
Howie Feltersnatch
07-14-2004 03:10 PM
Turbo Joe
03-11-2001 01:00 PM
