New 2018/2019 Maps Available
I didn't see a topic on this yet, but it appears the new 2018/2019 map versions are available from my.audi.com. I'm downloading them as we speak and hope to install via SD card later today.
1 Post
Can you spell exactly what steps you took to make this work? It seemed very straight forward to me but the Java tool (the download tool) was only 19KB in length and would NOT run so I could use an assist.
Thanks.
Well I am GLAD you are making this work because I tried it yesterday a half a dozen times with NO success!
Thanks.
Thanks.
Once that is done I moved the files from the folder to my 32 GB SD card. I then installed the SD card into the SD slot in my S3, pressed the menu button on the MMI system, went down to settings, clicked the left menu button, and I believe went to system preferences. Once the MMI was up and running there was an option for System Update that become available to select and I chose the SD card as the source. It is now installing now, and will do so in the background (this is the third time I've done it so I'm used to it) and so it should be done later tonight sometime, probably within an hour.
It does the update in the background? Does this mean that after I started the update installation, I can shut down the car, then use (drive/shutoff) the car as normal and it won't affect the update?
I was able to download a small number of regions OTA, but that could have been as part of the Audi Connect trial. It was one of the options along with SD, USB, etc., and it wasn't automatic.
