Replacing Air Filter - help!
I'm struggeling with this guys, I have disconnected the lower right air pipe, but the top one has a lot harder plastic joint that makes it impossible to even budge more than a couple mm. And also, the little breather hose, how do I go about removing that? Any pictures or detailed directions would be appreciated!
Ok figured it out after all. pushed the little breather hose off with a flat plastic tool, wiggled the big air pipes off with Hulk-force while clamping the springs, tugged the whole box up as it is secured with rubber ball-joints, like the little engine cover is, then from there I flipped it, unscrewed the 2 screws under the box, replaced filter, and put it back in reverse
Normally yes, but not the typical design on this model, i could easily do that on my old golf MK5, but this one doesnt have any screws, just 2 UNDER the filterhousing. But yeah, will probably take me 5 minutes next time, in stead of 2 days looking for any clip or thread on this model.
I should have looked at the picture before posting. My comment applies to A3/S3 8V chassis i.e. late model which is the forum that you are posting. You obviously have an earlier or different model
obLu
03-17-2010 06:46 AM
Gary P (sans Audi)
09-14-2002 04:13 PM
