S3 Pre-Sense Early Warning
I have a 2016 Prestige S3 with pre-sense (not the basic, I have ACC). There is an option in the MMI to keep pre-sense active but turn off the annoying early warning prompts. I can turn off the prompts while I'm driving, but every time I start the car again the early warning is turned back on in the MMI. I have a US spec vehicle. Does anyone else notice that this option doesn't stay inactive after shutting off and starting the car again?
Audi S3 early warning system can't be turned OFF
The early warning can't be turned off as there is no mechanism to turn it off. You can certainly untick the early warning, but there is no way to click on OK or accept this change. You can get rid of the early warning altogether by unclicking on SYSTEM, but I don't want to do that. I just want to get rid of the early warning for good. It is a damn nuisance.
Audi pre-sense is quite worthwhile. When it is really needed, it looks very effectively, even to the point of applying ABS braking for a sudden stop, but early warning is a joke- it is not necessary at all.
Akin to the nuisance early warning system is the reversing camera which beeps all the time unnecessarily, but when it was necessary once, it did not beep at all (I backed into a low lying bush).
It would appear that Audi need to smarten up their detection system considerably.
Maynerd
Q5/SQ5 MKI (8R) Discussion
07-09-2014 06:19 AM
lorengphd
08-19-2009 12:54 PM
WG_20V
12-13-2003 11:25 PM
