USB port not charging
#11
Since I checked my fuses and I don't have an actual fuse in location F16, I'm going to assume that isn't my problem. Must not be needed unless you have full MMI capability.
#12
VCD settings for USB Port?
It can be set to any of the options via VCD, but Audi decided to dumb it down depending on your car's model/location. Thought it was pretty interesting find while in the VCD settings. I only have the 3.5mm jack so haven't been able to play around with it - though I have the module , just not the cables to connect it to my MMI. I'd suspect it will act just like the SD card slots if data is enabled.
#14
Hi
A4 2012 Cigerette lighter and all USB ports stopped working. Went into Audi for a recall job and I asked to check them out. No voltage at ports but voltage at fuses.
They wanted £200 to investigate further. Report states J519 wiring and J807 relay static report. Not found much from online search.
Anyone any ideas where the J807 relay is?
#15
rooster 2
02-17-2006 05:09 AM
audiman231
06-29-2003 07:03 PM
