TPMS FOR RS5 2013
TPMS FOR RS5 2013
HI,
I am trying to enable TPMS for my RS5 have done the changes below . My car is with 1AT for the ABS/ESP system buy it did not come enabled
Enable TPMS
* You need the 1AT ABS unit – check your stickers (1AS does not work)
[Hidden menu] [car] [cardevicelist] [RDK] Enable
[Hidden menu] [car] [carmenuoperation] [Tires Air Pressure Control] Set to 5
[03 - ABS Brakes]
[Security Access - 16] (probably with login code: 61378)
[Coding - 07] -> Long Coding Helper -> Byte 1
Bit 3 - Tire Pressure Monitoring (PR-7K6) active (1 = active)
The TPMS need to be enabled in the Instrument Cluster:
[17 - Instruments]
[Coding - 07] -> Long Coding Helper -> Byte 4
Bit 0 - Tire Pressure Monitoring (TPMS) installed (1 = active)
Reset MMI
but get the Tyre Pressure Monitoring in MMI is grayed therefore cant reset it .
thank for any leads
photo of MMI screen att
Enable TPMS
[03 - ABS Brakes]
[17 - Instruments]
Reset MMI
thank for any leads
Tom Barber
02-28-2000 10:29 PM
