Audi A5 / S5 / RS5 Coupe & Cabrio (B9) Discussion forum for the B9 Audi A5, S5 and RS5 Coupe and Cabriolet 2018 model year and up
2018 S5 Sportback Lowered on 20s
Old 12-10-2017, 04:50 PM
  #111
BreedsAs's Avatar
No problem Freesole!
Old 12-12-2017, 05:34 PM
  #112
BreedsAs's Avatar
I just pulled the front bumper again to get ready for an intensive install on the RS style grille.
I removed the crash bar also so I can drop it off to be powder coated semi gloss black. That's the only way to get a lasting coat on it.
I'll also figure out a way to get the front camera installed too. After that, my front end will be done.
I'll update at the end of the week in a new thread as this one is too long.
Mock up. That raw aluminum crash bar stands out so bad.
Crash bar removed and ready to be dropped off. I'll also be putting holes around the areas marked with permanent marker for the parking sensors.
Old 12-12-2017, 07:12 PM
  #113
3cat's Avatar
I am fighting the peer pressure to buy this grill..... Not easy thanks to you
Old 12-13-2017, 08:55 AM
  #114
Yoshimura's Avatar
Originally Posted by BreedsAs
On to the 034 drop springs, they ride really good. They are supposed to only give .8" of drop, but I cannot tell you the net amount of drop with certainty because I installed the 20s (which have a tire about 1" greater in diameter) and the drop at the same time.
I don't understand why people measure from the ground instead of from the wheel centre...
Nice ride!!!
Old 12-13-2017, 12:46 PM
  #115
Quattrings's Avatar
Very nice BreedsAs - Looking forward to seeing your pics!
Old 12-13-2017, 04:24 PM
  #116
BreedsAs's Avatar
Thank you guys! This grille process has been a lot more frustrating than it should have been, but it's about to be all worth it.
UPDATE:
I got the front impact/crash bar to the powdercoat place today. They will be covering it in a more durable black powder that's kind of a semi gloss black textured finish. It's literally meant for bumpers and fender flares. Kind of resembles rhino liner. It'll be done in a few days.
I also got the notches (for the parking sensor brackets to clear the new grille provisions) cut and smoothed down by a local metal fabrication shop.
Last of all, I used a soldering iron to make two very small circular holes in the RS style grille, on the bottom side of the Audi rings emblem. I then used four (2 per side just in case) small black zip ties to zip tie the OEM camera mount rear bracket to the RS grille with the holes I made.
The result is a pretty strong and non moving front parking camera on the RS grille!!
You will also have to trim a part of the bracket so it is not visible from the front.
Old 12-14-2017, 11:10 AM
  #117
BreedsAs's Avatar
Almost there!
Old 12-14-2017, 12:34 PM
  #118
Stratman22's Avatar
Damn,that's gonna look sick! I can't wait for the finished look.
Old 12-15-2017, 03:56 AM
  #119
Quattrings's Avatar
Bumper looks sweet with that mesh grill BreedAs!
Old 12-16-2017, 09:07 AM
  #120
BreedsAs's Avatar
Default Crash/Impact bar back
The bar is back from powdercoat.
Almost done with the reinstall. Accidentally broke through temperature sensor bracket that clips into the bar. 🤦*♂️
Quick Reply: 2018 S5 Sportback Lowered on 20s
