Anyone w/ rear dashcam?
#41
I went with Thinkware F770 soon after I got the car and I do have a rear camera on the rear deck. It was between Thinkware and Blackvue because I want the parking mode function. I set the Thinkware to auto shut off when it detects battery power at 12.1v. Power came from fuse box with a tap-a-fuse. Need 1 power source which is ignition switchable, and another power source which is hot all the time. Cable ran up the A-pillar to the Thinkware main unit. The rear camera cable ran down a-pillar on the passenger side and tug along the bottom plastic trim piece to go to the rear deck.
Another option would be to go with a separate dashcam just for the rear and tap into the power source in the trunk. So instead of 1 SD card which has both front and back videos, you will have 2 separate sd cards.
#43
Dished out about $300 and finally I have my Thinkware F800 Pro hardwired. Cables are pretty much invisible. Neat job.
Also, Best Buy's Geek Squad guy failed to figure out how to do so as the car's a completely new model and he had absolutely no references. Tried my luck at another place at Tukwila, WA. They too were struggling to figure things out but after a whole day at the shop, they got it done.
#44
#45
I tried best buy first, the guy could not figure things out as the car's a brand new model and he did not have any reference to help him with the install.
#46
$450 for front + rear thinkware and another $300 for the install. $750 total. I am not really an expert with electrical stuff, and in order to enable parking mode in thinkware, it's gotta be hardwired. $300 didn't seem too bad especially after seeing that they had to take a whole day to get it done.
#47
The car is already packed with cameras.. I wish Audi would just offer a DVR option. Record 24 hour loop front and rear with ability to view recordings in car, or offload via WiFi & SD card.
#48
Well I got bought a Thinkware F770 from blackboxmycar. I am having a local car audio shop install it for 120-130.00. Does this sound reasonable for a front and rear dash cam install ?
#50
I simply removed all 3 rear headrests and stored them in plastic bags in the basement. I never carried rear seat passengers in my A3 over 12 years, and I probably won't in this car either. Rear visibility is much improved. If go for a rear camera, I'll probably just install another Viofo A119S in back. Not sure about parking mode though.. Current draw over the summer when I'm on the bike most of the time might be a problem.
