Auto Hold Button Installation
#221
Success!!
So I got it installed thanks to this thread My Only issue which is minor is the light illuminates at night but there is a slight flicker to it. Might need to tap into the main parking brake illumination wire. But overall 10/10, I can now give my foot a rest
As you can see the auto hold is now functional on the cockpit
Button Installed and functioning correctly
#223
Thanks to everyone in this thread. I just got this retrofit installed on my B9 A4. Everything works great and no faults. I used an OBDII to code. Bought my button from eBay ($40) and wiring kit from AliExpress ($15). The most stressful and difficult part was removing all of the trim panels. If you have a storage compartment to the left of the steering wheel you have two remove two additional bolts behind the storage compartment door to take the kick panel out. Overall it took me around 4-5 hours but that was partially due to working in an apartment building garage with barely any light and people walking around me.
#225
Looks like everyone else are saying that start/stop ignores if Auto Hold is engaged or not. Once you take your foot off the break pedal, the engine will restart. Is that not the case for your car? The only reason that I haven't done mine is due to this.
#226
Looks like everyone else are saying that start/stop ignores if Auto Hold is engaged or not. Once you take your foot off the break pedal, the engine will restart. Is that not the case for your car? The only reason that I haven't done mine is due to this. Or is this just a coding issue?
#228
#230
