Calibration for ACC & DAP
After 17k miles, I'm going to replace my OEM Continental ContiSport Contact tires on my 2018 S5 Sportback with Michelin Pilot Sport All Season 3s. My car has the Adaptive Cruise Control system and also the Driver's Assistant Package and I'm wondering if I need to get the camera's calibrated after I replace the tires. I've spoken to 4 different Audi dealership and they've given me different answers. 2 of them said I have to get the cameras calibrated for $500, 1 of them said I don't have to get the cameras calibrated but need to get the wheels alignment done for $130, and the 4th dealership said that they won't know if I need to get the camera's calibrated until they look at the system. Wondering what you guys have done. Thanks in advance.
No you do not need to get Audi pre sense recalibrated. It will need to be recalibrated if you perform an alignment though, as you should if you have new tires.
Why would new tires have an effect on the alignment? I would think if it's just a maintenance issue, than it would be better based on the mileage.
Swapping tires does not require calibration of anything,
Swapping tires does also not require an alignment UNLESS the tires being replaced show signs of uneven wear unrelated to improper tire pressure.
Not correct. You don't need to do an alignment when you replace tires. You also don't need to recalibrate the sensors when you do a suspension alignment. If a dealer is telling you otherwise they just want your $.
YMMV. Can you get away without doing a calibration? Sure. If it starts acting up, the car's still in warranty right? They'll just do a calibration, but don't be shocked if any phantom Pre sense issues are resolved after it.
Nikon1 (02-13-2020)
My observation is, if a service is under warranty, dealer will tell you it's only needed if you experience issues or if the system throws a fault code.
If the service is out of pocket, they will tell you to get it done every year, every time you change your tires, every time it rains, every time your wife is pregnant...
Point is, no you don't need to have your cameras calibrated when replacing tires. The only time you need cameras calibrated is if your front bumpers have been replaced, your windshield have been replaced, or if when they do an alignment they adjusted the rear toe.
Shep 1.8T
07-19-2005 06:26 PM
