Didn't shift to 1st gear when stopped
#11
Starting in second isn't nearly as bad for an automatic transmission as it would be for a stick, automatics uses a torque converter to transmit power to the transmission rather than a clutch plate. Many new automatics often start out in second gear as a default unless you put them in a sport mode or mash the throttle from a stop. This is done for smoother acceleration and better fuel economy.
#12
You can code it using an OBD11 device. I believe there is a one-click "app" to enable this feature via the OBD11 app for a few credits or if you get the Pro license you can manually code this feature along with a lot of other things by referencing the below thread without needing credits.
https://www.audiworld.com/forums/aud...018-a-2954987/
#17
I thought this was already a well known Audi fuel saving trick.
#18
