FasTrak Hidden Mount
#21
Club AutoUnion
Even though your authority is switching to stickers, those stickers may still have RFID circuitry within them. It would require the RFID “scanners” to use higher powered “exciters” to generate the return signals from the car mounted RFID antenna / stickers.
There are are multiple levels of RFID and how much intelligence can be stored in surface mount technology and system on a chip has increased dramatically since RFID was implemented.
I have no idea what California or other areas are using — I just know what the Mid-Atlantic is currently using is pretty old technology.
#22
perhaps in the sticker version they will have a switch built in that allows you to short out the antenna. Antennas are pretty finicky and need to be tuned just right so if you shorted them to other metal you would drastically change their resonant frequency and therefore be unreadable to a scanner so when you have multiple occupants. Just a guess tho. Frankly I don’t want a box, I don’t want a sticker, I don’t really want anything on this car that wasn’t out there by audi
#23
I’m bad. No front plate, (required in NJ) painted my EZ Pass black, (will plastic dip next time) and keep the transponder in the glove box. It has always been read in the lanes that require you to slow down, never received a notice from passing through the high speed lanes. I do have my plate registered with the system.
#24
Why do people bother with keeping FasTrak transponders in their car? All of our toll booths have cameras that capture your license plate and it gets logged into your FasTrak account. I haven't had a transponder in my car for years and it has never missed capturing my plate.
edit: unless you are using the express lanes or parking garages
#25
Permanent S Mode Member
#26
Quick update: I had the mount printed in PLA and it turns out it can't handle direct sun exposition, it's all twisted like a pretzel now. I'm having it reprinted in SLS and I'll see if it's more stable in the heat.
#27
That's a shame that it's shape distorted but I'm not that surprised it couldn't handle direct sun. It's black which will absorb a lot of heat and it's printed out of a material with a low melting point so it gets soft in the sun relatively easily. Changing to SLS might improve it's heat resistance some, but don't be surprised if you have a similar outcome .
#28
faiz_twinzdaddy
07-12-2006 04:12 PM
STASIK_A4
04-03-2005 07:07 AM
5221
01-02-2005 07:05 PM
