Presense and ACC malfunctions
I have been searching for a possible cause here on the forums but have not located anything. I have 2 warnings which I am sure are related. 1 Presence is limited check owner manual and 2 ACC not available, check owner manual. Not sure what could be causing these. Anyone have some input? I have reset the MMI, toggled the P sensors to no avail. I have an appointment at the dealer for next week.
Forgot to add, car has 15K miles.
Thoughts?
Thanks, JJ
Thoughts?
Thanks, JJ
Probably a sensor malfunction... I had a front level sensor replaced which caused presense to limit and issues with the dynamic suspension. Should be an easy fix, although they may have to order the part in. Good luck!!
Thoughts?
Thanks, JJ
Thoughts?
Thanks, JJ
starting ...
12-28-2005 09:51 AM
lskolnick(original)
9
02-10-2003 08:32 AM
JTravinski
06-12-2002 07:21 AM
Cuban90S
12-13-2001 07:00 AM
