RS5, as quick as a Civic Type R?
#11
They say they weren't in Dynamic and used Individual instead to put the Diff into Comfort. However, shouldn't they have then dropped the transmission into "S" instead of "D?" You can clearly see the transmission is in "D" in the video on the lower right at about 2:48. Dynamic normally puts you into "S," but they used Individual. I haven't tried that in my own RS5 since I either use Dynamic or Auto in "S" mode. Does Individual with the Engine and Trans in Dynamic have no difference in throttle response in D versus S? I need to test that in my RS5.
#13
Answer:
On-track, putting the diff in Dynamic or Auto mode brings the RS5’s tail into the game, but not in a good way. The rear end steps out when trail-braking into a corner, when adding throttle exiting a corner, when the track falls away, or if you start thinking about how bees are dying at an alarming rate. The unwanted rotation only gets worse on hot tires, and the Audi’s weight problem means it takes only one fast lap before the Hankooks begin to surrender their grip.
We resort to the RS5’s Individual drive mode, choosing Dynamic mode for the trans, engine, and suspension but setting the diff in Comfort to rein in the time-robbing slides. This keeps the diff from inciting dramatic yaw. And while it largely results in terminal understeer, that stability ensures we could clip off a quick lap before overheating the tires. While it’s not the most exciting way around a track, the RS5 is easy to drive at its limits and goes into the Climbing Esses without protest at 124.9 mph. Body control is exceptional for a heavy car, and the brakes are superb. A 3:03.9 matches the Civic Type R’s lap and is 0.4 second quicker than the time set by the old V-8–bearing, 4053-pound RS5.
#14
but the question is...
Answer:
#16
That's my thought as well. On my RS5, there is a night and day difference between D and S for throttle response, shift points, etc. while in Auto of Individual normally. Idle RPM is even held significantly higher, for example, and in S the exhaust is opened (unless already opened in Individual). I'm going to confirm this later tonight since I've never set Individual with all settings on Dynamic with just the Diff on comfort to see if there's a difference between D and S.
#18
I just tried this in my RS5. I programmed the ADS Individual to be all Dynamic except for the Sports Diff. When you select Individual with those settings, the car automatically defaults to S. You need to manually shift it to D. In D, the throttle response is much slower and the car shifts up early to lower the RPM just like it behaves with the ADS on Auto.
#19
#20
