RS5-Style grills, difference between EMD and eBay Chinese products?
#92
Appreciate the enthusiasm To each their own I guess. I have gathered an incredible amount of free knowledge / inspiration from this forum and its members. The least I can do in return is contribute to the common purpose and help a few folks out.
Project Update: Handed over the grille, camera, and the existing OE rear camera bracket to the designer earlier today. Just received the initial renders. Need a few tweaks but this guys is on it!
#93
Was actually just about to post this evening. I was away all last week on vacation and met up with the designer yesterday. Below is a pic of a printed semi-final version. I need to check this weekend if the camera angle is good and it clears the grille (field of vision does not catch the mesh below lens). May have to ask him to push the camera out a bit more... will determine after test. Part will be painted and sanded before final install. He will provide the final working file once we ensure the angles are good and camera has a clean field of view. Stay tuned, few pics below:
#96
Huh, does EMD no longer have the RS style grill for the B9?
#98
They don't come with parking sensors. If you get the grill with the large hexes throughout (like OEM RS5), you can use your existing sensors and you may need to slightly notch your bumper bar where the sensors rest so that they won't touch. Mine touch and sometimes the right-side sensor gives off false readings randomly, I think it's because I didn't notch it and it's touching the bumper bar. If you get the grill with the smaller hexes at the bottom (unlike OEM RS5), you'll need to get some low profile sensors somewhere since they're located higher up compared to the other model grill and rest over your bumper bar.
#100
