2001 Suspension and Warning Light Problems
I have a 2001 Audi Allroad. I have had it for about a month after going from a B5 S4 for the space. Obviously, just about anyone who has this car knows about the suspension issues. It seems that everyone has different problems and nothing is ever really the same. Everything was great and then one day the left from tire was down after sitting outside. Sometimes the right front will also sag as well. Now the lights sensor and suspension sensor is on and won't turn off. I have checked for leaks on the left front and can't find anything. I have taken it to the shop and no one can find the leak and also the shop computer can't make sense of the error codes and the answer from the shop is replace everything. Also strangely enough sometimes the shocks don't sag, but the warning lights still stay around.
I think I am going to take a shot at the Tire Slime trick and see if that holds. If that works and the light still stays on does that mean that there is a leak or could there be a computer control issue or a light sensor issue?
Any help or link to a post that could help would be killer. Thanks.
Sebas
Sounds like you have bag leaks. Mine was doing the same thing with random drops on the fronts. One side then days later the other and sometimes both. Got worse when it got colder. I replaced both fronts with Arnott Gen I's 3 months ago and hasn't sagged since.
Did the shop scan with a VAG-COM? What was the code? Generally leaky bags won't throw a code unless the compressor is getting weak and can't correct the sag in a timely manner.
I never got any codes while my bags where failing. Always popped right back up when door opened or restarted.
Still sounds like you may have some bag leaks, but I would do the sensor first.
If you search there is a write up somewhere of someone taking the sensor apart and successfully cleaning the contacts inside to get it working again.
I am thinking that I will have it checked at one more shop just in case, because it does need new struts at some point and also the auto leveling does not seem to be working when I get on the highway. I am hoping that it is just one bag.
Has anyone ever had a leak in one bag and found that the other side falls slightly as a result? I hope it is not the compressor.
Thanks for the help. I really love this car and am thinking of just scraping the entire system and putting the Arnott Coil Springs in.
When I finished, it was late, and wasn’t able to drive it around, but I did cycle the suspension up and down a few times. The next morning I was disappointed to find the car back in the sagged position again, but I decided to take it for a drive and see if that would improve things... Voila! It's been 100% perfect for the past 10 days. I’m convinced it worked, and for just $10
'02 Allroad 2.8 Tip Quattro
'01 Silverado 1500HD
'06 KTM 450XC-G
http://forums.quattroworld.com/allroad/msgs/45450.phtml
PS: You can never have too much info/knowledge!!!
