2003 Allroad 2.7t, NO HEAT!!!
I've posted on this exact thing ad nauseum for the last 3 months (search my posts) since I've been a new allroad owner.
The problem is most likely a blocked/clogged hearer core, especially if "everything" else checks out. The reason you're getting a momentary blast of warm-ish air is because the hot coolant will slowly and reluctantly flow thru your clogged core, but as soon as you extract the heat off by turning on the blower, the coolant doesn't circulate with enough volume, or fast enough, to replenish the core with new, hot coolant. So your heat remains tepid and pathetic.
If you find some other reason, or come up with a fix, PLEASE let us all know, because there are several of us watching these "heater" posts for a cure other than a core swap. Unless I read of some other cause, I'm swapping the core myself after i survive this winter.
So, are you saying that even though my heater lines are both hot, that the core could still be clogged? I get no heat at any engine speed.
Also, I'm starting to have trouble with the air suspension & my torque converter. This car will be sold as soon as I can sell it... Any takers?
I haven't done this yet, but I plan to and hopefully fix my issue. Maybe the flush only applies to the A4... let me know if I'm missing something here.
I don't have time to search now but you can access diagnostic program on climate control by pressing some two buttons together, it will show you all temp sensors outputs etc which might be the issue with your car. If for example heaer core temp sensor is shut and shows cold all the time, the system will never enable heat. Just search the forums or even better google for this.
It is also possible that some output functions cam be acxtivated with vag-com/vcds so that you can determine what's not jiving in the system.
One other trick is to remove the coolant res and lift it as high as possible when filling the engine. It adds a little more force to help remove air. Raising the front of the car may also help slightly.
Steve
I have flushed my core myself six ways from Sunday, then had a shop flush it and the whole system, and bleed the **** out of it; and it STILL would not flow coolant in the correct direction; I had to swap hoses to get it to flow at all, and both of my hoses now are hot to the touch at the firewall, yet my heat at the defrosters and floor is warm at best. It WILL get hotter as the outside ambient temp rises, which only indicates that what hot air IS coming off the core by the blower motor isn't being cooled as fast as it travels thru the heater box.
I believe that the continued gunk that comes out with every flush indicates that the interior is coated with years-old coating, and is NOT ALLOWING HEAT-TRANSFER FROM THE COOLANT TO THE FINS, AND THEN TO THE BLOWER AIR. This is why the core feels hot at both hoses at the firewall, but no real heat into the cabin. You mechanical engineers that remember your heat-transfer classes from college check me on this.
I still stand by my inefficient heater-core theory, only really corrected by a core swap.
The system works perfectly as it should... It just blows cold air. For instance, if I set the system to "auto" it doesn't blow hard until the heater core warms up... Just as it should. If this didn't happen, I would suspect that the heater core wasn't getting warm enough, but it is. I've checked everything else, & I'm at a loss. The other problem could be a sensor somewhere???
I'm now trying to decide if I want to tear apart the dash to see if a blend door could possibly be jammed or broke. Or if there is a broke sensor... Quite honestly, I think I'll just bundle up for the rest of the winter... I've got bigger fish to kill.(torque converter!!!)
I'm seriously trying to figure out why in the hell this car is so popular. It's most definitely overrated.
My understanding was that on AUTO, the fan blower would begin to come on as the ENGINE temp came up, not the heater core temp. If that's the case, my theory about the heater core not transferring heat is still valid.
Good luck, let us know if you check the blend door motor.
Not to rub it in your face, but your TC problem is why I bought a 6-sp. Still, I'm no fan of constant shifting, I WISH I was driving an auto.
Well, I don't know anything about the sensor either... I'm just relaying information I've read. Your theory makes more sense. I'm gonna flush it tomorrow & see what happens. I wish I would've known more about the TC issue too, but my other car was wrecked & I got a descent deal on this one. Just FYI.
I know that the manual says to use G12, but can this gummed up problem really happen? Or is it a corrosion issue? If anyone who has ever swapped a heater core has any insight, that would be some good info. To my knowledge, G12 is all that has ever been put in this car. The fluid looks about as orange as it could be. Anyhow, maybe it's the G12 that causes the problem!
Glad to finally have heat, although it's nowhere near as hot as it could be!
