2003 Allroad 2.7t, NO HEAT!!!
Glad to finally have heat, although it's nowhere near as hot as it could be!
My heat "came back" to some extent after I, and then the shop, flushed my core. I myself collected TONS of sandy and flaky crap into my flush bucket, and the shop soaked it for a while in cleaning solution before their final flush.
Heat came back (only when swapping heater hoses at the core), but that was a couple of months ago, and now at 20 deg outside, I can't tell if it's diminished again, or just wasn't really up to the task after all that work to begin with.
You took the first obvious step and I hope it works out for you!
No one has gone so far as to swap the core yet, have they???
Anyhow, this is off the subject, but I did get the torque converter replaced... I bought one from 517 Transmissions. They had very fast shipping & a reasonable price. I sent the core in today so that I could get my $300 back. I am happy so far since the dealers quote was $3600!!!! I had the new one put in by a local shop who specializes in after market upgrades to VW products. I was only charged $600 labor + $48 for fluids! So, I'm looking at a grand total of about $1252 for the total cost! I'm very happy with that. My normal mechanic, who is very good wanted about $1700 for the labor(he was quoting rack rate + what the book says as far as how long it will take). Anyhow, if you are in the northern Illinois area, go to Autohaus in Machesney Park. Tim is very fair & knowledgable about Audi/VW cars. He knew about how long it would take him & quoted me $600 labor before doing the job. When I picked up the car, he stuck with that price. Nice guy! Highly recommended!
I'm likely going to be doing airbags next... I've talked with him & again, he quoted me an awesome price & also offered to change the ride height if I wished for that. I'll do some research before I decide on that change... I don't want to drastically change the comfort of the ride.
This sounds rational, and is the general idea to attach a garden hose (using one of those Prestone hose-attach couplings, somehow)to the system and flush everything out thru a low point, like the bottom of the radiator?
I am running only G12 & distilled water. I bought the car with 81,000 miles, so I can't speak for what was put in it before I bought it. I didn't run CLR through it, but I will when winter goes away & I have the patience. As for now, it's keeping my windshield clear & me warm.
As for the heater core, you could get some extra regular heater hose and connect it to the heater core and fill it with CLR and let it soak. Just make sure its filled, so attach two hoses to it and hold them upwards higher than the heater core ports so you can allow the CLR to completely fill the core and let it soak. Then flush it out in reverse flow with a garden hose. If you have access to compressed air, I would give it a few blasts in reverse flow also before reconnecting it back to the cooling system. Then see if the heater core performance is improved. Just make sure you flush out all of the CLR before hooking it back up. You don't want that stuff flowing through your coolant system.
