2011 AUDI A4 Q Avant (47-Sound System -- Status: Malfunction 0010)
My 2011 Audi A4 Quattro Black rear left door main B&O speaker is not producing sound.
I ran a diagnostic test using my Ross-Tech HEX-V2 Dual-K & CAN USB system, and it came up with the following Fault Code:
I believe I have an open loop circuit so I removed the associated door panel for a closer look and it appears to be in order behind the panel.
Anyone else had an open loop speaker leading to the rear door main speaker, if so where was the break?
Here is the full fault code breakdown:
Address 47: Sound System (J525) Labels:. 8T0-035-223-BOM.clb Part No SW: 8T0 035 223 AN HW: 8T0 035 223 AK Component: DSP Prem H10 0190 Revision: 00010001 Serial number: 34804002857801 VCID: 7AADF3719CD23DE7841-802E 1
Fault Found: 02558 - Rear Left Mid-Range/Woofer Loudspeaker (R159) 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 5 Fault Frequency: 1 Reset counter: 104 Time Indication: 0 Freeze Frame: Voltage: 12.50 V Temperature: 15.0°C Temperature: 15.0°C Bin. Bits: 00000100
ayap
S4 (B8 Platform) Discussion
38
02-16-2012 05:52 AM
Greyhound Guy
01-25-2001 02:08 PM
larryV
06-04-2000 04:39 PM
