allroad ideas---
allroad ideas---
I have a 03 allroad that is essentially Stage 1. I've done all the usual bolt-on upgrades at this point. The car is currently at the dealer with 95K on factory pre-owned. Car needs turbos and 2 airbags. Fortunately they are going to pick up the tab under the warrranty-- very cool about the car being chipped. Based on the work needed, what would be some upgrades that you would recommend, if any? RS4 mounts? K04'S or GT's? Exhaust. Sounds like a good opportunity to do some more upgrades. Dealer has been very good to work with.
I'd ask about upgrading to K04 units & RS4 mounts. You can always do the ECU tuning later, ...
... without having to pull the engine a second time.
At least, this is how I understand it. Hopefully someone more clueful than myself will respond
if your engine is gonna be out - definately do K04's
I'd also do piggy pipes and an upgraded clutch (assuming a manual) while the engine is out.
fueling, software, and exhaust can all be done later without too much problem.
if you really wanted to go big - turbos bigger than K04s, a 3.0 crank, forged pistons, and a 2.8 head. but that starts to get expensive.
Quattro Copas
08-15-2009 04:31 PM
