Anyone else think ABS/ESP is hyper sensitive, especially when raised?...
Old Aug 2, 2007 | 11:46 AM
spedrcr's Avatar
Default Anyone else think ABS/ESP is hyper sensitive, especially when raised?...
I find that even pulling into my shop with a good 2 inch lip at less than 3 mph makes the ABS kick in like crazy. If raised, it's very easy to make the ABS kick in, steel plates in the road, offsetting sharp angle bumps in the road, even up to 35mph. Happens when applying the brakes or not, but more frequently if the brake pedal is depressed.
Besides cleaning the ABS sensors and rings, any other ideas? I'd love to mount a body camera shooting the front wheels in motion to see how much air the tire really gets over these "bumps". Pulling into my shop should not kick the ABS on as easily as it does. By the way, I have started turning off the ESP to minimize this annoyance. I can't imagine what it would be like off road. It was certainly not easy to drive in the snow with the ABS always working. 2002 AR 2.7T Tip w/82K mi and good pads and rotors all around.
Thanks in advance.
Old Aug 2, 2007 | 06:55 PM
paulroad's Avatar
Tech Guru
I tend to think your steering angle sensor needs to be re zeroed with a VAG -Com.
Old Aug 2, 2007 | 07:06 PM
gragravar's Avatar
yours sounds like it is misbehaving, I have never had any issue like that.
Old Aug 2, 2007 | 07:14 PM
ColoradoDriver's Avatar
Default You have a defective ABS/ESP module......
Technical service bulletin (TSB) #A45-04-01 "ESP Premature Intervention" from November 30, 2004
ABS/ESP modules D55 and earlier are affected.
PhilMason
Jan 3, 2011 02:24 PM
GIAudi
Apr 23, 2010 11:48 AM
Mike55123
Jun 21, 2007 12:52 PM
ReWa
Audi allroad
Mar 3, 2006 07:38 AM
tiptop
9
May 24, 2001 08:20 PM
