Boost Problem - need help
Old Nov 2, 2009 | 09:32 AM
muddycharles's Avatar
Default Boost Problem - need help
ABout three weeks ago I started having a boost problem (not enough boost)
The allroad is stage 1 APR chipped and has been for over a year.
Accelerating out of a toolbooth it was like someone took the boost off (or made it stock again)
The car hits max 8psi boost and usually is at about 4-5psi when accelerating. (I have a boost gauge)
So far we have checked the following:
1) Vaccuum Test
- Positive on Air intake (no leak)
- Negative on Canisters that connect to Secondary Air Pump (holds pressure)
2) Changed N112
3) Changed N75
4) Changed Diverter Valves (710N)
The car does not throw any errors other than Negative Charge Pressure (No MIL)
I think the following still need to be checked
A) N249
It says 27-30 ohms - we checked it and its at 26.5 Ohms - is that OK or not?
B) IC leak
Have not checked this although in some way it should have shown up when we did the pressure test
C) Turbo Valve (mechanical) stuck open or closed - if I remember the N75 valve connects to a mechnanical device that controls the opening and closing of the turbo valve on the exhaust side of the turbo. If ONE of these is closed - perhaps this is the problem???
D) Bad Turbo
When I accelerate I hear a turbo spool up - i dont know if its one or two, and there is no smoke or drilling screeching sound. I would hazard a guess that the turbos are working - although I cant speak to whether the exhaust side valve is open.
ANY SUGGESTIONS OR HELP ARE WELCOME - Im running out of things to change
Thanks
Alex
Old Nov 4, 2009 | 04:57 PM
04 allroad's Avatar
I stand corrected. As for the boost leak, did you check the Throttle Body Boot?
Old Nov 5, 2009 | 05:22 AM
Default Sheesh all I wanted was some help
Not a flame thread on one forum vs another. The point of these things is to give help. Suggestions appreciated by those that posted.
Thanks
Alex
Old Nov 5, 2009 | 02:14 PM
04 allroad's Avatar
Thanks
Alex
Did you check the throttle body boot?
exklusiv2
Audi Original "S" Cars
Apr 22, 2009 01:37 AM
GBW
May 16, 2008 06:12 AM
a4_1.8t_01
Oct 24, 2007 06:35 PM
Psychosel238
Dec 2, 2005 10:27 AM
bnl107
12
May 26, 2005 04:44 PM
