Which brake pads would you recomend to use with DBA slotted front brake rotors?
Re: I read some posts here, but got an impression that they didn't know or didn't follow
I have read in several places that the slotted discs are a good innovation, shedding heat better, though the cryo treated discs do better. but drilling just creates a place for stress cracks and warping to start, no real benefit. Watch the heat cycling, and they should be OK. Seating the new pads will help a lot (glazing a pad kills braking performance and pad life). Good luck!
Let's say I drive car very agressivly. 2 times changed rotors under the warrenty. Now I have 49K
and no free chees for me...delear refuses to change rotors this time.
I'd try the Zimmerman's,.
only 150 for both fronts. Keep your wheels torqued properly and you'll be good to go. I have Mintex RedBox brakes and have been very happy. You can check with the brake forum also for more suggestions.
