bulb replacement
bulb replacement
Low beam bulb blew out last night. Before tearing the front end off; could someone give
me the direction to go on replacing ? Quick look it appears that I would have to release the
2 clips behind the assembly- is this correct ? Also, what's the latest hot bulb PIAA's ?
Thanks for the help,
Harry
Harry
Re: PIAA makes a 3800k bulb... the "Superwhite".
Ahhh... no, not xenon. Sorry.
For Xenon, Phillips and Sylvania are the main guys to buy from. I'd try a Google search for sources... =)
Re: bulb replacement
They Work !!!!! Went outside to take the unit apart
and the bulb works !!! Am now checking the engine
compartment out to see if I can find anything labeled
"LUCAS" !!!!!!1
Harry
"LUCAS" !!!!!!1
Harry
Low-beam Xenon bulb replacement instructions from Bentley...
Low beam bulb (gas discharge headlight), replacing
WARNING! High voltage!
Make sure to disconnect battery Ground (GND) strap before performing work on parts of gas discharge ( xenon ) headlight marked with yellow high voltage symbols.
Notes:
Obtain radio code before disconnecting battery.
Be sure to activate vehicle features (radio, clock, electric window regulator, engine) according to owner's manual when the battery is re-connected.
Removing
- Remove housing cover from headlight housing.
- Disconnect connector -1- at gas discharge headlight and retaining ring -2- by turning counterclockwise.
Installing
Installation is reverse of removal, noting the following:
- Insert new bulb into housing, do not touch glass cone with bare hands.
- Place retaining ring -1- with both notches (arrow) onto locking lugs -3- of gas discharge headlight -2- and then tighten by turning clockwise.
- Re-connect harness connector and close housing cover.
HTH,
Notes:
Removing
Installing
HTH,
Theun
15
03-18-2006 03:18 PM
siberian
03-27-2002 08:14 AM
GreekTTCharlie
08-27-2001 02:03 PM
