CAM Timing Code, Exhaust Gas Temp Code, Coolant Temp Code
Old Dec 8, 2010 | 02:13 PM
jwadz626's Avatar
Default CAM Timing Code, Exhaust Gas Temp Code, Coolant Temp Code
All,
Wife had the allroad (2005 2.7T - 68,000 miles) out this AM and recieved a check engine light at startup. Drove it to work and then to the indy shop and did not experience any issues in terms of engine / performance outside of the light. Codes come back as three codes - CAM Timing Code, Exhaust Gas Temp Code, and Coolant Temp Code - sorry was not there to get the specific code ids. They do not seem to be related - Talking with the mechanic over the phone he had not experienced those three codes together and reset the light to see if it happens again. Has been driven a little since with no re-occurance - seems to be running in a normal condition. Looking for community input and wondering if anyone has had this combo / experience of if someone knows if these three sensors are on the same circuit. Could I get lucky and have this just be a 'fluke' condition or am I dreaming?
Old Dec 8, 2010 | 05:46 PM
thejulex's Avatar
Originally Posted by jwadz626
All,
There is only one circuit and it is ECU. I believe that EGT nor Coolant Sensor code would not trip CEL light but cam timing will. So it is possible that you've had the other two for a long time and two have a new tenant and that's just too much for ECU...
As said, reset and see what comes back.
cranky
Oct 15, 2009 08:33 AM
gliTTch
Mar 15, 2004 02:17 PM
S4MeNos
VAG-COM Discussion
Nov 11, 2003 01:29 AM
Crazy Ivanski
Feb 27, 2001 08:04 PM
