CEL and P2182 code
Old Oct 14, 2009 | 12:16 PM
cranky's Avatar
Default CEL and P2182 code
So my wife's '03 TT has had the CEL come on, go back off for a while , then come back on again - the code stored is P2181 which is supposed to indicate cooling system malfunction.
I've done a bit of research and it appears the suspects are: faulty coolant temp sensor vs. thermostat vs. fan(s). Fans are working fine, the engine seems to warm up normally, the temp needle comes to its usual spot and stops, etc. No evidence of overheating.
I read one post where the guy replaced the t-stat (the CEL light did go out afterwards), but when he tested the old one it seemed to work OK. The consensus theory was that perhaps the old one wasn't opening at the desired RATE, and that tripped the code.
If its something that trivial, and I gather it may well be, I'm tempted to ignore this.
Any thoughts on this?
Old Oct 15, 2009 | 06:05 AM
SlapTTy's Avatar
Did you actually VagCom it, or just get the code from a generic code reader? Not sure if a Vagcom scan would shed any more light on the CEL issue.
Old Oct 15, 2009 | 08:33 AM
HaTTfield's Avatar
Coolant temp sensors are very cheap, I've replaced mine twice due to a CEL being thrown.
Togglehead
Audi allroad
Sep 21, 2015 11:07 AM
PaulNZallroad
Audi allroad
Sep 17, 2015 04:46 AM
mdkv5
A6 (C7 Platform) Discussion
Sep 16, 2015 01:09 AM
spaniel1287
Sep 10, 2015 02:02 PM
