Does this work for rear pad replacement? And, what tool can I use to retract the caliper pistons?
AudiWorld Uber User
I always used a BAscrewdriver, but aritcle uses needle nose pliers. Is there a PepBoys alternative I can use?
Thanks<ul><li><a href="https://www.audiworld.com/tech/wheel2.shtml">https://www.audiworld.com/tech/wheel2.shtml</a</li></ul>
Re: Does this work for rear pad replacement? And, what tool can I use to retract the caliper piston
I have used a pair of water pump pliers and a c-clamp in the past. I did break down and buy the Harbor Freight brake tool. Well worth the $40.00 plus shipping
Wow - A guest appearance by teh hardcore AWOTer M3L10n b4L!Ar
Not the most graceful, but you can usually make this work:
<img src="http://woodbutcher.net/images/normstools/c-clamp.jpg">
Press and turn. Most c-clamps have a swivel head on the threaded rod
You tighten the clamp up nice and firm and then use channel locks or somethign to turn the swivel head on the clamp. Due to pressure the friction should be enough that the brake piston will turn too. Once it goes in a bit the friction will reduce and you'll have to tighten the clamp up again. It need good firm pressure in addition to the turning.
S4_NE
06-23-2008 06:25 AM
adminisTerTurbo
14
08-01-2006 06:55 AM
TittieTwister
11-23-2005 05:25 PM
