garage door opener.
garage door opener.
I have tried to program my Audi homelink transmitter (in visor) unsuccessfully .mY GARAGE DOOR REeCIVER MOTOR IS A wAYNE dALTON. I have pushed the program button on the motor head and the usual in car programming prompts.. the transmitter will blink slow but not sppeed up as if it was accepting new code... I have erased old codes in transmitter 2 or 3 xs ??? anyone else have this problem and resolved it ??
Re: garage door opener.
I went to search forums and found 1043 posts on garage door openers. followed some threads and called up homelink. they told me that because I have a black antenna on my motor that the homelink transmitter wont work, and that I must buy a universal one. 70 $ plus shipping and handling.. advised home Depot. So I guess I have found answer,and will cease fruitless programming attempts . Thanks all.
It's a diabolical process. You need the original transmitter, the receiver, and the car visor.
First program the car to the transmitter. That's easy. If there is a rolling code - Program the receiver to the visor. You are done. Get the instructions and follow the steps. Know that the press and release intervals may vary. Try it a couple of dozen times before you give up.
What color is your antenna wire sticking out?
I had the same issues and found I needed to buy a new updated board for my opening with a yellow antenna instead of the white one. Took ten minutes and cost $75 but love the HomeLink feature.
Call your local Dalton dealer and give them the model number and they will tell if it is compatible with HL.
TGABTG
A4 (B7 Platform) Discussion
11
10-04-2006 06:02 AM
BASELINE
18
12-12-2003 12:10 PM
