Headlight Problem
Replaced the bulb, replaced the ballast, still nothing. Circuit tester shows power in the gray and red wire in the plug going into the back of the headlamp housing.
High beam, fog light, side marker and turn signal all work.
Any help is greatly appreciated.
Relatively easy to just buy a used headlight from eBay and swap out the ballast instead of figuring out the smaller components. Good luck!
